I am using the Cynical SecuritySpy Plugin 1.4.2 with Indigo 6.0.1. SecuritySpy 3.1.1 is managing two cameras. Normally the plugin works fine with Indigo, but every day or two the plugin seems to run away, consuming large amounts of cpu resources on my Mac Mini Server. The activity monitor indicates that Indigo and the Indigo plugin handler are consuming almost all of the Mac Mini's resources. Reloading the Cynical SecuritySpy Plugin solves the problem, reducing Indigo cpu usage to a very reasonable level. When I reload the Cynical SecuritySpy Plugin, the Indigo logs usually report that Indigo could not quit the plugin normally, and had to force quit it. After force quitting, the plugin does start up normally with both cameras being reported properly.
I have created an Indigo Action Group to restart the Cynical SecuritySpy plugin, but periodically restarting the plugin is not a very satisfactory long term solution. Any ideas?
