Communications with Network Device ERROR 10,835
Tue Aug 20, 2013 6:59 pm
ukie offline
I am running Indigo 6.0.1 SecuritySpy 3.0.4 and Cynical SecuritySpy 1.4.2. Indigo and SecuritySpy are running on the same machine.
I've been getting this error (see image) ever since I updated Cynical SecuritySpy to 1.4
This is causing my mac to max out the CPU!
The problem occurs with an RTSP stream camera connected to SecuritySpy.
The camera does not actually ever loose connection in SecuritySpy or Indigo as the Cynical error alludes to.
My other Foscam camera is not having this issue.
May I again point out that this issue was not present when I had Cynical SecuritySpy 1.1.2.
Screen Shot 2013-08-20 at 17.47.04.png (97.95 KiB) Viewed 2053 times
Sat Aug 24, 2013 12:55 am
ukie offline
Re: Communications with Network Device ERROR 10,835
Does anyone have the previous version 1.1.2 that I can download?
Mon Sep 09, 2013 10:47 pm
Perry The Cynic offline
Um... which version of SecuritySpy were you using that version 1.1.2 of the plugin with?
Cheers
-- perry
Mon Sep 09, 2013 10:51 pm
ukie offline
Version 3 of SecuritySpy.
The errors started occurring after updating the plugin.
Tue Sep 10, 2013 12:17 am
The endlessly-repeated error message comes from SecuritySpy. Regardless of what causes the repeating effect, it's a real error message, indicating that SecuritySpy had trouble talking to the (network) camera. You may want to figure out why.
Oh, and try the version 1.6.1 of the plugin that I just posted.
Cheers
-- perry
Sun Sep 22, 2013 11:06 am
ukie offline
I understand that there might be a communication error but it should not persist in the plugin since it's only momentary in SecuritySpy.
I have tried version 1.6.1 which has a new issue (see attached image).
Yet the SecuritySpy server did not report anything and the plugin does not attempt to reconnect, I have to restart it manually.
Screen Shot 2013-09-22 at 10.04.20.png (8.82 KiB) Viewed 1701 times
