Cynical SecuritySpy: Integrate SecuritySpy with Indigo
Thu Jul 07, 2016 1:47 pm
mikejandreau offline
Re: Cynical SecuritySpy: Integrate SecuritySpy with Indigo
I upgraded to SecuritySpy 4.0 and 2.0.0 of the SecuritySpy plugin for Indigo, but none of my "Motion Detected" Triggers seem to be working.
Here's an example of one that's incredibly simple: http://take.ms/NJkZi
No Conditions, just a Pushover Action in Indigo.
The Camera in question is armed for "Actions" with "Armed all the time", but even when I walk in front of that camera, Indigo doesn't detect any motion at all.
The Camera itself is detecting the motion, because the M turns red, but the Indigo Trigger never happens.
This is the same for all 3 of my Indigo/SecuritySpy Triggers since the upgrade. Am I missing something? Does the camera in SecuritySpy have to be armed a different way, or do my Triggers need to change somehow?
Thanks for any help you can offer.
Thu Jul 07, 2016 7:43 pm
Perry The Cynic offline
Hm... "works for me." Ahem.
The intent is that if you're using SecuritySpy 4, then "active" means "motion detect enabled", and everything works the way it used to. It certainly does on the SecuritySpy beta I've got sitting on my computer here. (I haven't upgraded for real yet.)
That looks right. Remember this will only fire at most every 10 seconds, but you should see it fire at least once. From what you're saying, you're not doing anything wrong.
Turn on verbose logging in the Cynical SecuritySpy config window and enter into the text field below (you may need to scroll): spy.core. Then jump up and down in front of your camera and send me the Indigo log. :-)
Cheers
-- perry
Fri Jul 08, 2016 6:56 am
Hey Perry,
No dice. It didn't log anything at all.
Did I set up the debug logging right?
The log captured my motion sensors of me going downstairs, but nothing in front of the camera:
Jul 8, 2016, 8:51:57 AM
Cynical SecuritySpy debugging enabled
Jul 8, 2016, 8:52:16 AM
Cynical SecuritySpy debugging module: spy.core
Received INSTEON "Stairs - Up" on (button 1)
Received INSTEON "Stairs - Down" on (button 1)
Received INSTEON "Kitchen Entrance" on (button 1)
Jul 8, 2016, 8:54:02 AM
Received INSTEON "Kitchen Entrance" off (button 1)
Received INSTEON "Stairs - Down" off (button 1)
Cynical SecuritySpy debugging disabled
Did I miss something, or perhaps setup the debugging incorrectly?
Fri Jul 08, 2016 9:48 am
mikejandreau wrote:
Hey Perry,
The "debugging module: spy.core" message indicates that your change was accepted. Did you try reloading the plugin?
Cheers
-- perry
Fri Jul 08, 2016 12:58 pm
Aha! Reloading the plugin was the step I missed.
Even though I upgraded to 2.0.0, it just needed to be reloaded.
I did that just now in trying to debug again and now it's working.
Thanks Perry!
Sat Jul 30, 2016 1:37 pm
ChopOMatic offline
Perry, I'm running the following, all on a single MacMini, and never get past a status for the SS server device of "preparing" for a while, after which it switches to "unavailable."
Apparently during my many attempts to get it configured correctly, it at some point saw one of the cameras because one (properly named) camera is populated as well; its status mimics that of the SS server device.
OS X El Capitan 10.11.16
Indigo 6.1.10
SecuritySpy 4.0.4
Cynical SS Plugin 2.1.0
The attached images show my config and I've been sure to reload the plugin after any change. Any thoughts?
Sat Jul 30, 2016 2:34 pm
In the Cynical SecuritySpy settings window, check the Debug checkbox and in the text line below, enter spy.core,asyn.http. Reload the plugin and send me the resulting Indigo log.
Cheers
-- perry
Sat Aug 20, 2016 9:46 am
jfeger offline
Great plugin, I've been using it for about 9 months now. Is the consensus that the plugin in its current form works as expected with SecuritySpy 4.0.4? Im not convinced I see features justifying the need to pay for the upgrade, but I do like to stay current if possible.
Tue Aug 23, 2016 8:02 pm
Swancoat offline
Perry The Cynic wrote:
Colorado4Wheeler wrote:
Another thing to note that the plugin uses is the Active/Passive is no longer there in lieu of giving more granular control over motion sensing and microphones. I'm on the fence about upgrading at the moment because I rely on those states.
The active/passive state is very much still there; it's just now called "Motion Capture" state. The UI has changed, but not the underlying functionality, and Cynical SecuritySpy version 4 just maps it (nothing changes in the plug-in).
Its my understanding that if you have a working setup with SecuritySpy 3 and Cynical SecuritySpy and upgrade to SS 4, then (if it still supports your cameras) it should work exactly as before. Of course, I've got about two hours of experience on that, right now.
Having said that, I totally understand sitting on the fence for a while. SecuritySpy 3 will work (and be supported) just fine. I hope.
Cheers
-- perry
Hey Perry, any plans to add the ability to control the 'action' status of the cameras? This more granular control from security spy suits me well, as I had my front door recording motion and emailing me a photo when it detected motion. Using your plugin I would shut that off whenever the alarm was disarmed (so I wouldn't get all these photos emailed to me when I was sitting at home).
However... now the plugin only disables the motion recording (which I'd gladly leave running all the time) and can't control the 'action' part (so it's either a bunch of emails while I'm home, or none at all for me).
http://nerdhome.jimdo.com
Wed Aug 24, 2016 9:07 am
It's on my list, but don't hold your breath...
Cheers
-- perry
Tue Sep 06, 2016 12:31 am
wmldwilly offline
Okay I wasn't holding my breath. But I'm about to start... :)
I've found SecuritySpy 4.x to indeed run much snappier and cleaner on it's host machine. I've got a fairly slick home monitoring thing going on, and sure enough - that inability to deal with this new somewhat split personality for "record when there's motion" or "don't record when there's not" has bitten me in the posterior.
I'm sheepishly asking Mr. Perry...any chance you've had a sec to look into that? :lol:
WM :mrgreen:
Tue Sep 06, 2016 9:17 am
roquej offline
Until Perry is able to update the plugin, I am using Action Groups with Python code to handle the new Actions option:
Disclaimer, I am far from a python programmer...
ARM ACTION:
import requests
username = 'INDIGO USERNAME'
password = 'INDIGO PASSWORD'
login_url = 'INDIGO URL:8000/++ssControlActions'
payload = (
('cameraNum', 1),
('arm', 1),
r = requests.get(login_url, params=payload, auth=(username, password))
For DISARM ACTION, just change arm=0 above. Of course, change the cameraNum to your particular setup.
Hope this helps.
JP
Tue Sep 06, 2016 10:27 am
citysnaps offline
Cheers
-- perry
In the mean time, to deal with your emails...
Have you considered letting Indigo handle that? Cynical SecuritySpy can send a camera motion event to Indigo, which can then trigger sending an email based on the value of an "away" variable.
I'm doing essentially that, except my trigger action sends me an iMessage with a photo from the motion-triggered camera.
Brad
Urban photoblog: www.citysnaps.net
Tue Sep 06, 2016 6:39 pm
Swancoat offline
Cheers
-- perry
The emails from SecuritySpy include a photo.
Fri Sep 09, 2016 10:06 pm
By a totally not coincidental coincidence, I just released version 2.2.0, with support for SecuritySpy 4 arm states. The documentation has been updated to match.
Cheers
-- perry
