Re: Error when adding a trigger for Cynical SecuritySpy
Posted: Thu May 02, 2013 7:56 am
Bensoftware wrote:Hi Dewster,
If you load http://securityspy-server-address:8000/++eventStream in a web browser (Safari, Chrome), after a short time you should see some events come up (maybe set the cameras to Passive then Active mode, that will send some events through and cause Safari to display the text), do you see motion events shown here? Please compare SecuritySpy 2.2.4 and 3.0.4 to see if there is a difference. If you enable motion recording in SecuritySpy 3.0.4, do you get files being captured in response to motion detection?
Results from 3.0.4
20130502095246 5 CAM0 PASSIVE
20130502095248 6 CAM0 ACTIVE
20130502095307 7 CAM0 MOTION
20130502095308 8 CAM0 MOTION
20130502095309 9 CAM0 MOTION
20130502095310 10 CAM0 MOTION
20130502095311 11 CAM0 MOTION
20130502095313 12 CAM0 MOTION
20130502095314 13 CAM0 MOTION
20130502095315 14 CAM0 MOTION
20130502095346 15 CAM0 PASSIVE
20130502095346 16 CAM0 ACTIVE
20130502095346 17 CAM0 OFFLINE
Results from 2.2.4
20130502095417 4 CAM0 ACTIVE
20130502095419 5 CAM0 PASSIVE
20130502095421 6 CAM0 ACTIVE
20130502095458 7 CAM0 MOTION
20130502095459 8 CAM0 MOTION
20130502095500 9 CAM0 MOTION
20130502095501 10 CAM0 MOTION
20130502095502 11 CAM0 MOTION
20130502095503 12 CAM0 MOTION
20130502095530 13 CAM0 PASSIVE
20130502095530 14 CAM0 ACTIVE
20130502095530 15 CAM0 OFFLINE
I should note, I thought before I was getting weird results if an action upon motion were selected, such as a beep or bringing up the preview camera window, however, this seemed to be on the last release and testing without anything checked still gave similar results to the 3.0.4 version above.
Update... not sure if the plugin didn't like the flip flopping between 3.x and 2.x or what, but a reboot of the server seems to have resolved the issue and I'm now registering motion without having a motion action selected. Thanks for all the work to get to the bottom of the issue to all.
