- Posted on
Wed Dec 24, 2014 2:55 am
McJohn
offline
Good day,
This morning at 6.30 hour, spontaneously Cynical Weather gives these continuous errors below.
Even after a reload of the plugin.
What could this be?
Thanks for the help.
John
Cynical Weather Error in runConcurrentThread: Traceback (most recent call last):
File ".../Server Plugin/cyin/debugging.py", line 46, in diagnostic_log
yield
File ".../Server Plugin/cyin/debugging.py", line 56, in diagnose_call
return method(*args, **kwargs)
File ".../Server Plugin/cyin/asynplugin.py", line 52, in runConcurrentThread
self.run()
File ".../Server Plugin/asyn/inject.py", line 49, in run
asyn.Controller.run(self)
File ".../Server Plugin/asyn/controller.py", line 91, in run
item._can_read()
File ".../Server Plugin/asyn/selectable.py", line 219, in _can_read
self._scan(input)
File ".../Server Plugin/asyn/scan.py", line 50, in _scan
self.callout(RAW, self._rbuf)
File ".../Server Plugin/asyn/core.py", line 140, in callout
results = [cb(ctx, *args) for cb in list(self._callbacks)] # latch callback list
File ".../Server Plugin/asyn/ssl.py", line 121, in incoming
self._service()
File ".../Server Plugin/asyn/ssl.py", line 97, in _service
self._scan(rdata)
File ".../Server Plugin/asyn/http_chunk.py", line 30, in incoming
self._pass_downstream(data)
File ".../Server Plugin/asyn/http_chunk.py", line 57, in _pass_downstream
self.callout('END', data)
File ".../Server Plugin/asyn/zfilter.py", line 32, in incoming
self.callout(ctx)
File ".../Server Plugin/asyn/http.py", line 280, in incoming
return self.callout('body', self.body)
File ".../Server Plugin/forecast/core.py", line 179, in cb
callout(asyn.Context('reading'), Reading(args[0]))
File ".../Server Plugin/forecast/core.py", line 124, in __init__
self.days = self._collect(s.get("daily"))
File ".../Server Plugin/forecast/core.py", line 142, in _collect
return List(data, self.units)
File ".../Server Plugin/forecast/core.py", line 91, in __init__
list.__init__(self, [Point(dp, units) for dp in points])
File ".../Server Plugin/forecast/core.py", line 40, in __init__
convert("summary", str, "")
File ".../Server Plugin/forecast/core.py", line 38, in convert
setattr(self, name, None if value is None else type(value))
UnicodeEncodeError: 'ascii' codec can't encode character u'\u2013' in position 13: ordinal not in range(128)
Cynical Weather Error plugin runConcurrentThread function returned or failed (will attempt again in 10 seconds)
