Getting this setup this weekend...
I got the network device setup with it's static IP in indigo as a device.
I believe I need to create an IR emitter device next? However, when I do that and edit device settings, hit the dropdown for address, the only address I see is --invalid--
Does the itach need to be directly connected to the mac during setup for indigo? Right now I have it just as a stand alone device with an ethernet cable.
I believe I'm on the right track here... then I would choose that emitter from an action, edit the device settings, learn, save that code and then be able to access it via indigo.
Am I way off track here or just running into issues?
Below is the event log during reload:
Starting plugin "Cynical Caché 1.1.0b8" (pid 782)
Started plugin "Cynical Caché 1.1.0b8"
Cynical Caché mapping device "Living Room AV" 1951616333(gcnet)
Cynical Caché Living Room AV starting
Cynical Caché Living Room AV connecting to network device 10.0.1.19
Cynical Caché plugin starting asyn operation
Cynical Caché using no IR database
Cynical Caché STDOUT: VERSION 710-1005-05
Cynical Caché Living Room AV ready with 3 device(s)
Update: Updated to Beta 9 (can we please get rid of the "b" so it's a simple double click to install?) and I can now see the three ports.
