security spy plugin - animal detection
Wed Aug 17, 2022 4:34 pm
agame offline
As of version 5.5.0, Security Spy supports AI recognition of animals, currently this trigger is not available in the plugin.
Any chance of getting this supported?
Wed Jan 04, 2023 9:37 am
whmoorejr offline
Re: security spy plugin - animal detection
Not sure if this will work with your current setup…. There is a “DeepState” plugin that was desigened with Blue Iris in mind, but can work outside of blue iris with a separate install of “DeepState” running somewhere else that the plugin can use. The plugin natively will take a “blueiris” camera image and send to Deepstate for object recognition, but you can also specify a URL to use instead…. So it should work with any camera system that has an image url (which SS does).
The writer of the Deepstate plugin uses it for detecting people and dogs
https://forums.indigodomo.com/viewtopic.php?f=222&t=24349
https://www.indigodomo.com/pluginstore/247/
I hope that helps.
Bill
My Plugin: My People
Wed Jan 04, 2023 9:59 am
McJohn offline
You can also use an Action Trigger into SecuritySpy to change a Variable in Indigo:
https://bensoftware.com/forum/discussio ... one#latest
John
