use custom states from a ghost xml device
Tue May 07, 2019 12:15 pm
bsp9493 offline
Not sure if this belongs here or somewhere else...
I have a ghostXML device setup that returns a number of custom states. (ie 2 different temperature values)
I need to calculate and then monitor the differential temperature between 2 of these values (ie 120 degrees - 80 degrees = 40) and then either store the number in a variable, or use the returned value in a trigger to perform another function (ie turn on a pump when the differential value is >40)
any suggestions?
dave
Tue May 07, 2019 12:57 pm
Re: use custom states from a ghost xml device
This is perhaps a little tricky because either (or both) monitored value could change. Or put another way, if you only trigger on changes to state 1, the differential could exceed your target when state 2 changes--without triggering anything. I think the safest approach would be to create a trigger for each value you're monitoring and fire a small script when one or the other changes.
The Action for each trigger would run this Python script (which would need to be modified for your installation):
dev = indigo.devices[DEV ID HERE]  # GhostXML device
state_1 = dev.states['STATE_NAME_HERE']
state_2 = dev.states['STATE_NAME_HERE']
var = indigo.variables[VAR ID HERE]  # result
if float(state_1) - float(state_2) > 40.0:
    indigo.variable.updateValue(var, 'True')
    indigo.variable.updateValue(var, 'False')
This is untested, but it should be pretty close.
Tue May 07, 2019 2:02 pm
bsp9493 offline
You are AMAZING... that's why I ask:)
Works like a charm!
I was looking at that in the indigo documentation, but yes, didn't think about monitoring both as you noted.
Thanx for the HELP!
dave
Access a custom device state
# get the device
dev = indigo.devices[23989834] # Some custom device
print unicode(dev.states)
Tue May 07, 2019 2:46 pm
Glad that worked for you. I've been thinking about this a bit more and this will only work if A - B > 40 is True. If it's possible for B to be more than 40 units greater than A, it won't work.
Only you know your data well enough to know if it's a possibility (or even one that you want to account for), but this small revision should account for both cases.
if abs(float(state_1) - float(state_2)) > 40.0:
Tue May 07, 2019 3:42 pm
bsp9493 offline
yes, I did consider that...
it's actually a bit more complex than that, but what you sent me got me going, it's not pretty the way I implemented it and I"m sure there's a better way, but it works for now, and gives me some time to explore other options :)
basically 2 independent solar water systems
trigger1on
monitors and compares airTemp and poolTemp
if difference is greater than 12, it sets frontTempDiff to true, else to false
trigger1off
monitors the same
if the difference is less than 8, it sets frontTempDiff to false, else to true
when frontTempDiff = true, it turns on poolPump 1 to low
when frontTempDiff = false, it turns off poolPump1
now it gets more difficult - LOL
trigger2on
monitors and compares solarTemp and poolTemp
if difference is greater than 12, it sets backTempDiff to true, else to false
trigger2off
monitors the same
if the difference is less than 8, it sets backTempDiff to false, else to true
when backTempDiff is true, it turns on poolPump1 to low AND turns on circPump
when backTempDiff is false, it turns off poolPump1 AND turns off circPump
so, there is the case where frontTempDiff is >12 AND backTempDiff is <8 (or vise versa) which depending on when the triggers run would give a conflicting command to poolPump1
I guess in a nutshell, I want to turn something(s) ON when one or both systems are at >12 degrees temperature differential, and turn something(s) OFF when both systems are <8 degrees temperature diff
Again, I appreciate the help:)
d
Tue May 07, 2019 5:02 pm
That kind of logic begs for a plugin! :D
Tue May 07, 2019 11:13 pm
Can’t you use a simple trigger “any change of a variable” or device/state
Then a small python script that does your math.
Thu May 09, 2019 3:28 pm
bsp9493 offline
I'm sure there is a better way, but this seems to be working...
set a trigger on temperature change, then set a couple of the variables. Once the variables are set, have a second trigger for on and off of the specific devices (pump1 and solarCircPump)
dev = indigo.devices[1422876465] # "Autelis - Status"
state_1 = dev.states['temp_airtemp']
state_2 = dev.states['temp_pooltemp']
state_3 = dev.states['temp_soltemp']
var = indigo.variables[466600928]  # solar true/false
var2 = indigo.variables[600100007] # solar side true/false
if (float(state_1) - float(state_2) > 12.0) or (float(state_3) - float(state_2) > 12.0):
    indigo.variable.updateValue(var, 'true') # one OR both devices over 12 will turn on pump1
if (float(state_1) - float(state_2) < 8.0) and (float(state_3) - float(state_2) < 8.0):
   indigo.variable.updateValue(var, 'false') # BOTH devices less than 8  will turn off pump1
if float(state_3) - float(state_2) > 12.0:
    indigo.variable.updateValue(var2, 'true') # will turn on circpump
if float(state_3) - float(state_2) < 8.0:
   indigo.variable.updateValue(var2, 'false') # will turn off circpump
    indigo.variable.updateValue(var, 'true') # tempdiff between 8 and 12 keep pumps running
    indigo.variable.updateValue(var2, 'true') # tempdiff between 8 and 12 keep pumps running
Thu May 09, 2019 3:55 pm
If it works and makes sense to you, it's a perfectly fine way to do it.
To make it even simpler, you could do the floats when you cast the variables, like this:
state_1 = float(dev.states['temp_airtemp'])
state_2 = float(dev.states['temp_pooltemp'])
state_3 = float(dev.states['temp_soltemp'])
if (state_1 - state_2 > 12.0) or (state_3 - state_2 > 12.0):
if (state_1 - state_2 < 8.0) and (state_3 - state_2 < 8.0):
if state_3 - state_2 > 12.0:
if state_3 - state_2 < 8.0:
A second way would be to use descriptive variable names rather than the generic name like this (if I didn't screw it up):
air_temp = float(dev.states['temp_airtemp'])
pool_temp = float(dev.states['temp_pooltemp'])
sol_temp = float(dev.states['temp_soltemp'])
solar_var = indigo.variables[466600928]  # solar true/false
solar_side_var = indigo.variables[600100007] # solar side true/false
if (air_temp - pool_temp > 12.0) or (sol_temp - pool_temp > 12.0):
    indigo.variable.updateValue(solar_var, 'true') # one OR both devices over 12 will turn on pump1
if (air_temp - pool_temp < 8.0) and (sol_temp - pool_temp < 8.0):
   indigo.variable.updateValue(solar_var, 'false') # BOTH devices less than 8  will turn off pump1
if sol_temp - pool_temp > 12.0:
    indigo.variable.updateValue(solar_side_var, 'true') # will turn on circpump
if sol_temp - pool_temp < 8.0:
   indigo.variable.updateValue(solar_side_var, 'false') # will turn off circpump
    indigo.variable.updateValue(solar_var, 'true') # tempdiff between 8 and 12 keep pumps running
    indigo.variable.updateValue(solar_side_var, 'true') # tempdiff between 8 and 12 keep pumps running
But those are a matter of taste. I find this is a good habit to get into, though, because I routinely look at old code and scratch my head while I try to remember what the hell I was doing. :D
Fri Dec 06, 2019 2:20 pm
wideglidejrp offline
I am attempting to pull stock price data from Alpha Advantage and then use the data for triggers which will adjust the color of an LED color strip on my office ceiling. I don't see how to get the actual data. My api query is:
https://www.alphavantage.co/query?funct ... R9DEIPRDTJ
I setup the device for UBER stock. If I choose the JSON option, it shows "Processing" but never changes. If I use XML option, it shows "Updated". The custom states I see are shown in the attached. What I don't see are the variables I expected which include open, high, low, close, volume. What am I doing wrong?
Screenshot 2019-12-06 15.17.54.png (84.57 KiB) Viewed 3338 times
John R Patrick
Author of
Home Attitude
Fri Dec 06, 2019 7:19 pm
The output is definitely JSON. There must be something different in the output from when I last checked the API (as I said when we chatted, it's been a while). If the JSON tool is balking, then something in the data is causing the tool to hang. When I get a little time, I'll have a look at the data -- hopefully, I'll be able to find the thing that's causing the problem. Similar things have happened in the past and we've been able to tweak the model to work around them. No guarantees, though, I'm afraid.
Sat Dec 07, 2019 8:10 am
Dave, thought I'd have a quick look at this, but I'm lost.
The JSON is intact on jsonlint.com checker, and looks simple enough.
981      if self.finalDict is not None:
982          # Create the device states.
982.x        indigo.server.log("prestate")              #THIS WORKS
983          dev.stateListOrDisplayStateIdChanged()
983.x        indigo.server.log("poststate")              #THIS DOESN'T
984
223      def getDeviceStateList(self, dev):
260          indigo.server.log("about to return")          #THIS WORKS
261          return state_list
262
This should give:
prestate
about to return
poststate
But for this data source, it only gives:
prestate
about to return
So the plugin is hanging/failing when trying to return state_list.
Another data source, to http://headers.jsontest.com, works fine.
Peter
Sat Dec 07, 2019 9:06 am
Thanks Peter for having a go.
I'm still working on getting a matplotlib plugin bug fix tested (hang in there Bert!) but my initial suspicion is that many of the Alpha Vantage keys start with a character or series of characters that Indigo doesn't like. A quick test in the Python interpreter also says the AV JSON is valid. We may have something in the GhostXML code already that's just not working properly, or perhaps it will require a new routine to ensure that all prospective keys start with a character that Indigo likes.
# Indigo shell:
>>> d = indigo.Dict()
>>> d['a'] = 'foo'
>>> d['1'] = 'bar'
  File "<console>", line 1, in <module>
StandardError: LowLevelBadParameterError -- illegal XML tag name character
# Python shell:
>>> d = dict()
>>> d['a'] = 'foo'
>>> d['1'] = 'bar'
>>> print(d)
>>> {'a': 'foo', '1': 'bar'}
Sat Dec 07, 2019 9:12 am
I did notice afterwards that this JSON is multilevel.
Data begins at JSON[‘headerinfo’][‘key’] = value (in pseudocode), but I’m sure you’ve got handling of that in the plugin already?
Sat Dec 07, 2019 9:49 am
I *think* multilevel should be okay. That's from memory, however.
It also goes without saying....more robust exception handling is needed. :)
