Many Thanks For Your GhostXML Plugin
Wed Jan 02, 2019 1:26 pm
daveHawk offline
I just want to say thanks for the plugin. I am a longtime user of WeatherCat software and had developed a collection of applescript interfaces to WC. Of course, with the upcoming deprecation of applesript I was facing a dilemma since there is no plugin for WC. I tried the weather software for which Indigo has a plugin, but it lacks many data points that I am tracking. So, I got to looking at GhostXML and it turns out to be The solution! Your work is much appreciated.
Thanks again!
Example of one of the WeatherCat-GhostXML Device Feeds:[/size]
<?xml version="1.0" encoding="utf-8"?>
<current_observation xmlns:xsd="http://www.w3.org/2001/XMLSchema" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" version="1.0">
   <location>L$</location>
   <daylight_hours>DAYLIGHTTIME$</daylight_hours>
   <dewpoint>STAT$DEWPOINT:CURRENT:TODAY$</dewpoint>
   <humidity_internal>STAT$INTHUMIDITY:CURRENT:TODAY$</humidity_internal>
   <humidity_percent>STAT$EXTHUMIDITY:CURRENT:TODAY$</humidity_percent>
   <pressure_mb>STAT$PRESSURE:CURRENT:TODAY$</pressure_mb>
   <pressure_high_mb>STAT$PRESSURE:MAX:TODAY$</pressure_high_mb>
   <pressure_min_mb>STAT$PRESSURE:MIN:TODAY$</pressure_min_mb>
   <pressure_trend>BTTEXT$</pressure_trend>
   <relative_humidity>STAT$EXTHUMIDITY:CURRENT$</relative_humidity>
   <rain_day_in>STAT$RAIN:TOTAL:TODAY$</rain_day_in>
   <rain_week_in>STAT$RAIN:TOTAL:THISWEEK$</rain_week_in>
   <rain_7day_in>STAT$RAIN:TOTAL:HRS(168)$</rain_7day_in>
   <rain_24hr_in>STAT$RAIN:TOTAL:HRS(24)$</rain_24hr_in>
   <rain_48hr_in>STAT$RAIN:TOTAL:HRS(48)$</rain_48hr_in>
   <rain_month_in>STAT$RAIN:TOTAL:THISMONTH$</rain_month_in>
   <rain_year_in>STAT$RAIN:TOTAL:THISYEAR$</rain_year_in>
   <rain_storm_in>RS$</rain_storm_in>
   <sunrise>SUNRISELOCAL$</sunrise>
   <sunset>SUNSETLOCAL$</sunset>
   <station_latitude>Llat$</station_latitude>
   <station_longitude>Llong$</station_longitude>
   <station_time>t12$</station_time>
   <station_time_sec>t12s$</station_time_sec>
   <temp_apparent_f>AT_US$</temp_apparent_f>
   <temp_heat_index_f>STAT$HEATINDEX:CURRENT:TODAY$</temp_heat_index_f>
   <temp_internal_f>STAT$INTTEMPERATURE:CURRENT:TODAY$</temp_internal_f>
   <temp_current_f>STAT$TEMPERATURE:CURRENT:TODAY$</temp_current_f>
   <temp_day_high_f>STAT$TEMPERATURE:MAX:TODAY$</temp_day_high_f>
   <temp_day_low_time>STAT$TEMPERATURE:MIN:TODAY:TIME$</temp_day_low_time>
   <temp_day_high_time>STAT$TEMPERATURE:MAX:TODAY:TIME$</temp_day_high_time>
   <temp_day_low_f>STAT$TEMPERATURE:MIN:TODAY$</temp_day_low_f>
   <temp_month_high_f>STAT$TEMPERATURE:MAX:THISMONTH$</temp_month_high_f>
   <temp_month_low_f>STAT$TEMPERATURE:MIN:THISMONTH$</temp_month_low_f>
   <windchill_current_f>STAT$WINDCHILL:CURRENT:TODAY$</windchill_current_f>
   <windchill_min_today_f>STAT$WINDCHILL:MIN:TODAY$</windchill_min_today_f>
   <windchill_max_today_f>STAT$WINDCHILL:MAX:TODAY$</windchill_max_today_f>
   <wind_dir_10min_avg_txt>WDTEXT$</wind_dir_10min_avg_txt>
   <wind_degrees>STAT$WINDDIRECTION:CURRENT:TODAY$</wind_degrees>
   <wind_rose_dir>WINDROSE8$</wind_rose_dir>
   <wind_day_high_mph>STAT$WINDSPEED:MAX:TODAY$</wind_day_high_mph>
   <wind_avg10_today_mph>STAT$AVERAGEWINDSPEED:CURRENT:TODAY$</wind_avg10_today_mph>
   <wind_speed_current_mph>STAT$WINDSPEED:CURRENT:TODAY$</wind_speed_current_mph>
   <wind_day_low_time>STAT$WINDSPEED:MIN:TODAY:TIME$</wind_day_low_time>
   <wind_day_high_time>STAT$WINDSPEED:MAX:TODAY:TIME$</wind_day_high_time>
   <wind_month_high_mph>PlaceHolder</wind_month_high_mph>
   <wind_ten_min_gust_mph>PlaceHolder</wind_ten_min_gust_mph>
   <wind_year_high_mph>STAT$WINDSPEED:MAX:THISYEAR$</wind_year_high_mph>
   <wind_run_today>STAT$WINDRUN:TOTAL:TODAY$</wind_run_today>
</current_observation>
Wed Jan 02, 2019 1:38 pm
Re: Many Thanks For Your GhostXML Plugin
Glad to hear that you're finding the plugin useful and thanks for sharing your results. Hopefully, others will benefit from what you've found.
