ah ha!!!
Found it, I had a Schedule set to update my pool variables, and hidden within the action there was the call to refresh the ghost xml devices.
Thanx for the help!!!
dave
gnikolov wrote:Hello, i have an error starting the pluggin, Can someone help me with that ?
Regards!
17/07/2018 14:09:41
Upgrading plugin GhostXML to newer version 0.4.07 (previous version moved to trash)
Loading plugin "GhostXML 0.4.07"
Starting plugin "GhostXML 0.4.07" (pid 558)
GhostXML
GhostXML ================================================ Initializing New Plugin Session =================================================
GhostXML Plugin name: GhostXML
GhostXML Plugin version: 0.4.07
GhostXML Plugin ID: com.fogbert.indigoplugin.GhostXML
GhostXML Indigo version: 7.1.1
GhostXML Python version: 2.7.10 (default, Oct 6 2017, 22:29:07) [GCC 4.2.1 Compatible Apple LLVM 9.0.0 (clang-900.0.31)]
GhostXML ==================================================================================================================================
GhostXML Error Error in plugin execution InitializeMain:
File "<string>", line 1, in <module>
File "plugin.py", line 82, in __init__
File "/System/Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7/logging/__init__.py", line 719, in setLevel
File "/System/Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7/logging/__init__.py", line 188, in _checkLevel
ValueError: Unknown level: u'1111111111'
Stopping plugin "GhostXML 0.4.07" (pid 558)
Stopped plugin "GhostXML 0.4.07"
gnikolov wrote:Hello again!
Yes it starts right now thank you.
Now, when i create a device i receive the next error. And the error is the same when i click the "Edit Device Settings..." Button.
Thank you! Best regards!
Error (client) getXmlFromPlugin() caught exception: incorrect type returned (expected XML string)
Error (client) runDialogForDevice() caught exception: NSInvalidArgumentException -- *** -[__NSPlaceholderDictionary initWithObjects:forKeys:count:]: attempt to insert nil object from objects[0]
GhostXML Error Error in plugin execution CallPluginFunc:
File "plugin.py", line 183, in getDeviceConfigUiXml
KeyError: key refreshFreq not found in dict
gnikolov wrote:Thank you!
Yes of course, its your work and i am very gratefull with it!
Thank you again, i will check it frecuently.
Kind regards!
