Maybe I found the culprit
The devices in question had authentication set to „none“
When I set it to „digest“ and leave the credentials empty instead, the device recovers automatically.
.52...
GhostXML Debug ReturnCode: -9
GhostXML Warning [OTGW] curl error * Adding handle: conn: 0x7fdb63810a00 * Adding handle: send: 0 * Adding handle: recv: 0 * Curl_addHandleToPipeline: length: 1 * - Conn 0 (0x7fdb63810a00) send_pipe: 1, recv_pipe: 0 * About to connect() to otgw.voyager95.de port 80 (#0) * Trying 192.168.1.52... . [Return code: -9
GhostXML Debug [OTGW] Parse Error: No JSON object could be decoded
GhostXML Debug [OTGW] jsonRawData {u'controlsp_description': u'Control setpoint', u'setpoint_description': u'Room setpoint', u'maxmod_description.ui': u'Max relative modulation level', u'flame_value': u'0', u'chwsetpoint_description': u'Max CH water setpoint', u'fault_description': u'Fault indication', u'modulation_value': u'0.00', u'boilertemp_description': u'Boiler water temperature', u'dhwtemp_value_dot_ui': u'48.05', u'otgw_firmware_name_dot_ui': u'Opentherm Gateway', u'chmode_description': u'Central heating mode', u'dhwmode_description': u'Domestic hot water mode', u'temperature_value': u'23.00', u'otgw_firmware_version_dot_ui': u'4.2.5', u'fault_description_dot_ui': u'Fault indication', u'setpoint_value_dot_ui': u'23.00', u'otgw_software_version': u'4.3', u'maxmod_value_dot_ui': u'100.00', u'controlsp_value_dot_ui': u'44.77', u'parse_error': True, u'deviceLastUpdated': u'01/12/2020 at 13:05', u'diag_value_dot_ui': u'0', u'dhwenable_description_dot_ui': u'Domestic hot water enable', u'otgw_software_name_dot_ui': u'Opentherm Monitor', u'temperature_description': u'Room temperature', u'fault_value': u'0', u'flame_value_dot_ui': u'0', u'diag_description': u'Diagnostic indication', u'otgw_firmware_version': u'4.2.5', u'dhwmode_description_dot_ui': u'Domestic hot water mode', u'returntemp_value_dot_ui': u'41.02', u'outside_description_dot_ui': u'Outside temperature', u'boilertemp_value_dot_ui': u'41.58', u'temperature_value_dot_ui': u'23.00', u'chmode_value_dot_ui': u'1', u'controlsp_description_dot_ui': u'Control setpoint', u'dhwenable_value': u'1', u'setpoint_description_dot_ui': u'Room setpoint', u'flame_description_dot_ui': u'Flame status', u'dhwsetpoint_description': u'DHW setpoint', u'dhwtemp_description_dot_ui': u'DHW temperature', u'diag_description_dot_ui': u'Diagnostic indication', u'returntemp_description': u'Return water temperature', u'otgw_time_dot_ui': u'2020-01-12 13:06:26 +0100', u'modulation_description': u'Relative modulation level', u'otgw_software_version_dot_ui': u'4.3', u'dhwtemp_value': u'48.05', u'dhwenable_value_dot_ui': u'1', u'otgw_software_name': u'Opentherm Monitor', u'outside_value_dot_ui': u'8.72', u'chmode_description.ui': u'Central heating mode', u'chwsetpoint_description_dot_ui': u'Max CH water setpoint', u'setpoint_value': u'23.00', u'controlsp_value': u'44.77', u'maxmod_value': u'100.00', u'deviceTimestamp': 1578830710.325386, u'maxmod_description': u'Max relative modulation level', u'temperature_description_dot_ui': u'Room temperature', u'outside_description': u'Outside temperature', u'boilertemp_value': u'41.58', u'dhwmode_value_dot_ui': u'0', u'outside_value': u'8.72', u'otgw_firmware_name': u'Opentherm Gateway', u'chwsetpoint_value_dot_ui': u'85.00', u'fault_value_dot_ui': u'0', u'dhwsetpoint_value': u'35.00', u'flame_description': u'Flame status', u'dhwsetpoint_value_dot_ui': u'35.00', u'chwsetpoint_value': u'85.00', u'chmode_value': u'1', u'deviceIsOnline_dot_ui': u'Processing', u'modulation_value_dot_ui': u'0.00', u'dhwtemp_description': u'DHW temperature', u'deviceIsOnline': True, u'modulation_description_dot_ui': u'Relative modulation level', u'returntemp_value': u'41.02', u'returntemp_description_dot_ui': u'Return water temperature', u'boilertemp_description_dot_ui': u'Boiler water temperature', u'diag_value': u'0', u'otgw_time': u'2020-01-12 13:06:26 +0100', u'dhwsetpoint_description_dot_ui': u'DHW setpoint', u'dhwenable_description': u'Domestic hot water enable', u'dhwmode_value': u'0'}
GhostXML Warning There was a parse error. Will continue to poll.
GhostXML Warning [OTGW] curl error * Adding handle: conn: 0x7fdc19025200 * Adding handle: send: 0 * Adding handle: recv: 0 * Curl_addHandleToPipeline: length: 1 * - Conn 0 (0x7fdc19025200) send_pipe: 1, recv_pipe: 0 * About to connect() to otgw.voyager95.de port 80 (#0) * Trying 192.168.1.52... . [Return code: -9
GhostXML Debug [OTGW] jsonRawData {u'controlsp_description': u'Control setpoint', u'setpoint_description': u'Room setpoint', u'deviceLastUpdated': u'01/13/2020 at 15:18', u'flame_value': u'0', u'temperature_value_dot_ui': u'23.47', u'fault_description': u'Fault indication', u'modulation_value': u'0.00', u'boilertemp_description': u'Boiler water temperature', u'dhwtemp_value_dot_ui': u'47.28', u'otgw_firmware_name_dot_ui': u'Opentherm Gateway', u'chmode_description': u'Central heating mode', u'dhwmode_description': u'Domestic hot water mode', u'fault_description_dot_ui': u'Fault indication', u'dhwmode_value.ui': u'0', u'otgw_software_version': u'4.3', u'controlsp_value_dot_ui': u'40.45', u'deviceLastUpdated_dot_ui': u'01/13/2020 at 15:15', u'setpoint_value_dot_ui': u'23.00', u'diag_value_dot_ui': u'0', u'dhwenable_description_dot_ui': u'Domestic hot water enable', u'otgw_software_name_dot_ui': u'Opentherm Monitor', u'temperature_description': u'Room temperature', u'fault_value': u'0', u'flame_value_dot_ui': u'0', u'diag_description': u'Diagnostic indication', u'returntemp_value': u'41.12', u'dhwmode_description_dot_ui': u'Domestic hot water mode', u'returntemp_value_dot_ui': u'41.12', u'outside_description_dot_ui': u'Outside temperature', u'boilertemp_value_dot_ui': u'42.03', u'otgw_firmware_version_dot_ui': u'4.2.5', u'chmode_value_dot_ui': u'1', u'controlsp_description_dot_ui': u'Control setpoint', u'dhwenable_value': u'1', u'setpoint_description_dot_ui': u'Room setpoint', u'dhwsetpoint_description': u'DHW setpoint', u'dhwtemp_description_dot_ui': u'DHW temperature', u'returntemp_description': u'Return water temperature', u'otgw_time_dot_ui': u'2020-01-13 15:19:37 +0100', u'modulation_description': u'Relative modulation level', u'otgw_software_version_dot_ui': u'4.3', u'dhwtemp_value': u'47.28', u'dhwenable_value_dot_ui': u'1', u'otgw_software_name': u'Opentherm Monitor', u'outside_value_dot_ui': u'10.11', u'chmode_description.ui': u'Central heating mode', u'otgw_firmware_version': u'4.2.5', u'setpoint_value': u'23.00', u'controlsp_value': u'40.45', u'diag_description_dot_ui': u'Diagnostic indication', u'deviceTimestamp': 1578925095.021134, u'temperature_description_dot_ui': u'Room temperature', u'outside_description': u'Outside temperature', u'boilertemp_value': u'42.03', u'flame_description_dot_ui': u'Flame status', u'parse_error': True, u'outside_value': u'10.11', u'otgw_firmware_name': u'Opentherm Gateway', u'fault_value_dot_ui': u'0', u'dhwsetpoint_value': u'35.00', u'flame_description': u'Flame status', u'dhwsetpoint_value_dot_ui': u'35.00', u'temperature_value': u'23.47', u'chmode_value': u'1', u'dhwmode_value': u'0', u'modulation_value_dot_ui': u'0.00', u'dhwtemp_description': u'DHW temperature', u'deviceIsOnline': True, u'modulation_description_dot_ui': u'Relative modulation level', u'returntemp_description_dot_ui': u'Return water temperature', u'boilertemp_description_dot_ui': u'Boiler water temperature', u'diag_value': u'0', u'otgw_time': u'2020-01-13 15:19:37 +0100', u'dhwsetpoint_description_dot_ui': u'DHW setpoint', u'dhwenable_description': u'Domestic hot water enable', u'deviceIsOnline_dot_ui': u'Processing'}
