Disable SQL logging not working?
Thu Jan 07, 2021 8:26 pm
Re: Disable SQL logging not working?
aldonc wrote:
Hi Matt, looks like that worked. I'll keep an eye and post back if I see continuing issues.
thanks, Aldon
Fantastic. Looks like that sorted it. The SQL Logging setting was a later addition to the plugin and it looks like there may be some instances where a plugin upgrade doesn't handle updating existing devices, or situations where the setting gets out of sync. I'll have a look at the code and see if anything looks fishy.
Thanks to Matt for helping to sort the issue!
Thu Jan 07, 2021 8:56 pm
aldonc offline
Hi Dave, Looks like I spoke too soon. It appears that even with Disable SQL Logging enabled, it tries to create the table.
I deleted a GhostXML device, I disabled SQL Logger, I reloaded GhostXML and re-created the device (with Disable SQL Logging enabled), then enabled SQL Logger and it recreates the table.
I have to get on a call for work so won't be able to experiment more tonight.
thanks, Aldon
Thu Jan 07, 2021 9:27 pm
Thanks Aldon - totally understand that you don't have time to do this tonight. When you do find the time, if you would be kind enough to run the following script and send me the results. If there are any data that are sensitive, please be sure to mask them. Change 12345678 to the ID of your device. The result below is a dummy device I use for testing.
indigo.server.log(u"{0}".format(dev.ownerProps))
The prop we're interested in is the bold one:
com.fogbert.indigoplugin.GhostXML : (dict)
curlArray : (string)
curlSubA : (string)
curlSubB : (string)
curlSubC : (string)
curlSubD : (string)
curlSubE : (string)
curlSubs : false (bool)
digestPass : (string)
digestUser : (string)
disableGlobbing : false (bool)
disableLogging : true (bool)
doSubs : false (bool)
feedType : JSON (string)
maxRetries : 10 (string)
refreshFreq : 60 (string)
sourceXML : http://httpbin.org/bearer (string)
sqlLoggerIgnoreStates : * (string)
subA : (string)
subB : (string)
subC : (string)
subD : (string)
subE : (string)
timeout : 5 (string)
token : Dave123 (string)
tokenUrl : (string)
useDigest : Bearer (string)
Fri Jan 08, 2021 12:49 pm
aldonc offline
Hi Dave,
Note that this is the device I described above (new device, etc).
     Interactive Shell               com.fogbert.indigoplugin.GhostXML : (dict)
     curlSubA :  (string)
     curlSubB :  (string)
     curlSubC :  (string)
     curlSubD :  (string)
     curlSubE :  (string)
     refreshFreq : 3600 (string)
     subA :  (string)
     subB :  (string)
     subC :  (string)
     subD :  (string)
     subE :  (string)
     token :  (string)
     tokenUrl :  (string)
     useDigest : None (string)
I removed the URL.
thanks, Aldon
Fri Jan 08, 2021 1:08 pm
Thanks Aldon -- that looks right to me. Based onMatt's message above, that looks like it should work. Matt said that the change would be applied in Indigo 7.5--are you on 7.5? If you're on 7.4 or earlier, I don't think there's anything I can do.
Fri Jan 08, 2021 4:16 pm
Dave – I think the problem is you are setting sqlLoggerIgnoreStates on dev.pluginProps instead of dev.sharedProps. Try something like:
sharedProps = dev.sharedProps
sharedProps["sqlLoggerIgnoreStates"] = "*"
dev.replaceSharedPropsOnServer(sharedProps)
You can keep it in pluginProps as well obviously, but when the UI is closed push it to sharedProps as well (hopefully that won't stomp on the other prop changes overwriting pluginProps).
Fri Jan 08, 2021 5:09 pm
aldonc offline
Just to confirm, I'm on Indigo 7.5.0.
thanks, Aldon
Fri Jan 08, 2021 6:05 pm
Thanks Matt -- that's something that seems like it would make a difference....
Aldon (and everyone else) I'll get on this asap.
