Feature Requests
Sun Oct 11, 2020 2:51 pm
Re: Feature Requests
Glad you were able to find a solution that worked for you.
Cheers!
Sun Jun 20, 2021 4:18 am
davinci offline
I tried your plugin to substitute FantasticWeather. But I can't get any data. This is probably because my API uses OAuth 2.0:
https://developer.srgssr.ch/faq
Is there any way you can implement this?
Thank you
Sun Jun 20, 2021 6:00 am
Thank you
I took a quick look at the API docs and it looks like that service should work with the existing plugin. Are you using the "Bearer" authentication type?
Sun Jun 20, 2021 7:16 am
davinci offline
Yes I tried, but it seems that I have to get the token first and it expires. Not sure how to automate this.
Sun Jun 20, 2021 7:35 pm
Sorry, I should've been more clear. I should have asked if you were using the "Bearer" auth type instead of the "Token" auth type.
Have you tried the API with the Token auth type?
Mon Jun 21, 2021 12:27 am
davinci offline
I do not have a token url.
I only have:
CONSUMER KEY
CONSUMER SECRET
Since I only have 50 request per day my testing capacities are limited. :mrgreen:
Mon Jun 21, 2021 5:10 am
Understood. I didn't write that particular authentication method into the plugin (it was added by @berkinet), but in looking over the code, the plugin asks for the token to be provided by the server and then submits the API call with "?access_token=XXXXXXX" to the end of the source URL. So if the token auth method within the plugin is going to work (it may not work), then the settings would be something like:
URL/Path: "https://URL that requests the actual data you want" (no quotes)
Method: Token
Token URL: "https://URL to obtain the authentication token from the server" (no quotes)
Password: CONSUMER KEY or CONSUMER SECRET
It may be that the token auth method won't work for your source. If that's the case--and if the authentication method your source uses is a universal one--we can see about getting it added to the plugin. :)
Mon Jun 21, 2021 6:20 am
davinci offline
This actually works in Terminal:
curl -X POST \
  'https://api.srgssr.ch/oauth/v1/accesstoken?grant_type=client_credentials' \
  -H 'Authorization: Basic <"KEY:SECRET"MANUALLY CONVERTED TO base64 >' \
  -H 'Cache-Control: no-cache' \
  -H 'Content-Length: 0' \
  -H 'Postman-Token: 24264e32-2de0-f1e3-f3f8-eab014bb6d76'
curl -X GET \
  'https://api.srgssr.ch/srf-meteo/colors' \
  -H 'Authorization: Bearer MANUALLY ADDED RECEIVED_TOKEN' \
  -H 'Postman-Token: 56128353-805e-4974-6689-5ef6d86e2d80'
The received token expires.
I don't know how to make it work with the plugin.
Mon Jun 21, 2021 6:24 am
Thanks -- that's going to be helpful in figuring this out. I have some IRL commitments today but will look at this asap and see whether this can be done/added to the plugin.
Tue Jun 22, 2021 12:24 am
davinci offline
Thanks, please let me know if I can help with testing. I have 50 tries today. :D
Tue May 17, 2022 5:29 pm
Monstergerm offline
I noticed that the 2022.0.1 version of GhostXML plugin writes to Indigo log every time a Ghost device is getting updated. I have several weather-related Ghost devices that update every 10 minutes, so this adds a lot of log entries.
I can easily suppress this code in the plugin (code line #1412), but I was wondering whether you could add a pref check box in the device config to suppress log entries for simple 'device updates'.
Tue May 17, 2022 6:48 pm
The quick fix would be to up the plugin logging to "Warning Messages" which would suppress device update messages. You might miss a few other standard messages, but with this plugin, "device updated" messages are the lion's share for sure.
