Setting URL input for JSON
Sun Mar 31, 2019 5:36 am
WouterK offline
I am trying to read some json information from a app which contains the values of my electric and gas usage.
Using the URL in a commandline it looks like:
'http://192.168.1.54/api/v2/datalogger/dsmrreading?ordering=-timestamp&limit=1'
/usr/bin/curl -vsk -H 'X-AUTHKEY: 5ZMCOBBXQGKLGJZD3TZZZJYXEMRURXDQABV89HN8HMUPS4P5M56PMZ4A5JRSYSHA' 'http://192.168.1.54/api/v2/datalogger/dsmrreading?ordering=-timestamp&limit=1'
* Trying 192.168.1.54...
* TCP_NODELAY set
* Connected to 192.168.1.54 (192.168.1.54) port 80 (#0)
> GET /api/v2/datalogger/dsmrreading?ordering=-timestamp&limit=1 HTTP/1.1
> Host: 192.168.1.54
> User-Agent: curl/7.54.0
> Accept: */*
< HTTP/1.1 200 OK
And this is works.
I am not able to use the single quotes in URL field of the GhostXML device config. Without the single quotes the URL gets the value :
GET /api/v2/datalogger/dsmrreading?ordering=-timestamp HTTP/1.1
/usr/bin/curl -vsk -H 'X-AUTHKEY: 5ZMCOBBXQGKLGJZD3TZZZJYXEMRURXDQABV89HN8HMUPS4P5M56PMZ4A5JRSYSHA' http://192.168.1.54/api/v2/datalogger/d ... mp&limit=1
[1] 18256
MacBook-Pro:~ wey3$ * Trying 192.168.1.54...
* TCP_NODELAY set
> Host: 192.168.1.54
> Accept: */*
< HTTP/1.1 200 OK
It is possible in some way to use the single quotes in the URL field or can/should I use another notation of the URL?
Regards,
Wouter
Sun Mar 31, 2019 6:17 am
Re: Setting URL input for JSON
You shouldn't put quotes around the URL in the GhostXML plugin, so you might first try it without the quotes.
If you need to use single quotes *within* the URL, you could try encoding them like this:
http://192.168.1.54/api/v2/datalogger/dsmrreading?ordering=-timestamp&limit='1'
would become this:
http://192.168.1.54/api/v2/datalogger/dsmrreading?ordering=-timestamp&limit=&#39;1&#39;
Although, that's untested. I'll add a note to the TODO list for the plugin to take a look at handling single quotes natively.
Sun Mar 31, 2019 6:36 am
WouterK offline
Thanks for the (quick) suggestion.
Without the quotes the url used becomes : http://192.168.1.54/'api/v2/datalogger/ ... -timestamp
After the "&" is not used.
Based on your suggestion I played with the position of the single quotes within the URL and found something that works :
http://192.168.1.54/'api/v2/datalogger/dsmrreading?ordering=-timestamp&limit=1'
Regards,
Wouter
Sun Mar 31, 2019 12:58 pm
That seems odd that the parameters following the '&' wouldn't go through. I'll do some digging and see what I can find.
Mon Apr 01, 2019 12:24 pm
WouterK offline
Great, thanks.
However, the notation you suggested is working.
Regards,
Wouter
Mon Apr 01, 2019 12:29 pm
Glad to hear it's working for you. Thanks for letting me know.
