Announcements Plugin Updates
Mon Feb 05, 2018 7:13 am
The Announcements Plugin has been updated.
v0.4.01
  • Updates plugin update checker to use curl to overcome outdated security of Apple's Python install.
You can download it here.
Tue May 15, 2018 6:20 am
Re: Announcements Plugin Updates
Version 0.5.01 of the Announcements Plugin has been released.
  • Now requires Indigo 7.
  • Updates devices states using Indigo API 2.0
  • Updates docstrings to Sphinx standard.
  • Fixes minor bug in setting of announcement refresh time when new announcements are first created.
  • Code refinements.
You can view the documentation here.
Mon Jul 30, 2018 4:58 am
Version 0.5.02 of the Announcements Plugin has been released.
This is an optional update. Users with functioning plugins can ignore this update.
  • Fixes bug in naming of PluginConfig.xml (which caused problems on systems set up as case sensitive).
  • Code refinements.
Wed Aug 22, 2018 5:58 am
Version 1.0.01 of the Announcements Plugin has been released.
  • Takes plugin out of beta.
  • Fixes bug where speak action returned all indigo devices and variables instead of only plugin devices.
  • Code refinements.
Sun Dec 30, 2018 7:38 pm
Version 1.0.02 of the Announcements Plugin has been released.
  • Removes plugin update notifications.
  • Moves announcement settings file to Indigo plugin preferences directory.
  • Code refinements.
Existing users of the plugin are strongly encouraged to make a backup of the announcements.txt file located in the root user folder under the /Announcements Plugin folder. The plugin update will move this file to the Indigo Plugin Preferences folder, but it may be helpful to have a backup of the file in case something goes wrong.
Sun Jan 06, 2019 6:00 pm
Version 1.0.03 of the Announcements Plugin has been released.
- Fixes bug when a Speak Announcement Action was called when there was no announcement to speak.
- Refines logging.
Tue Jan 15, 2019 7:10 am
Version 1.0.04 of the Announcements Plugin has been released.
  • Fixes critical bug where restarting the plugin can delete saved announcements.
CRITICAL: all users of v1.0.02 and v1.0.03 should create a backup of their saved announcements file (located at /Library/Application Support/Perceptive Automation/Indigo 7.2/Preferences/Plugins/com.fogbert.indigoplugin.announcements.txt) and then apply the patch immediately. Restarting the plugin before updating to v1.0.04 can cause saved announcements to be deleted. Users of versions prior to v1.0.02 can update at their leisure.
Sorry for any inconvenience!
Thu Mar 14, 2019 4:06 pm
Version 1.0.08 of the Announcements Plugin has been released.
  • Fixes bug in substitution generator where generator was returning only plugin devices.
  • Improves responsiveness to changes to the plugin preferences.
  • Changes "En/Disable all Announcements Devices" to "En/Disable all Plugin Devices".
  • Performance improvements.
