Nanoleaf Essentials A19
Tue May 04, 2021 11:09 am
SearchCz offline
Does this plugin work with the Nanoleaf Essentials A19 bulb ?
Tue May 04, 2021 11:23 am
autolog offline
Re: Nanoleaf Essentials A19
I don't know as I haven't tested it. I have tested with the Aurora (triangle) and Canvas (square).
More recently, I have been having issues with my Auroras but the Canvases are OK.
It would probably need some code changes to support the A19.
Mon May 10, 2021 11:04 am
SearchCz offline
So, I added a couple of these essential A19s to the home. They work with HomeKit like a breeze ... super easy integration. Unfortunately, they don't show up in the device list through the NanoLeaf b=plugin, as you expected since they are neither Aura nor Canvas. Seems like a nice capable bulb though.
Mon May 10, 2021 12:59 pm
autolog offline
OK, I can take a hint. ;)
I have just ordered one for testing.
Once I get it, I will schedule in some time to include support for it in the plugin. :)
Wed May 12, 2021 6:18 am
autolog offline
Unfortunately, it looks like there isn't an API available for the A19 (at the moment). :|
The A19 is one of the first nanoleaf devices using Thread technology.
I will do further investigation but I am not overly optimistic that it will be possible to control these lamps from Indigo (at least in the short term)
Wed May 12, 2021 11:38 am
Even if the API investigation goes nowhere, since these are HomeKit bulbs, you could use HomeKit Bridge and the virtual switch trick to control them.
1. create a virtual switch. Let's call it A19 Control.
2. Publish it to HomeKit via HKB.
3. Create a HomeKit automation that turns on the A19 any time A19 Control turns on, etc.
4. Automate the A19 Control as you normally would in Indigo.
Sat May 15, 2021 2:40 pm
SearchCz offline
Of course that's what I did ! Good enough for controlling off and on, but a bit clumsy when it comes to adjusting color and brightness, or incorporating into scenes. I have it set up now to cycle through an assortment of presets whenever I get an "on" command from a particular remote/loadless Insteon switch. I'll see if I can post a video of it.
Sat May 15, 2021 2:47 pm
SearchCz offline
That would be amazing, Jon, and much appreciated !
Wed May 11, 2022 10:55 am
SearchCz offline
Any good news on these A19 bulbs?
