Plugin doesn't seem to work - gives RGB Conversion error.
Posted: Tue Nov 10, 2020 4:01 am
I used to have the plugin working perfectly. Then one day I started seeing 'no ack' from our various Nanoleaf devices. I deleted the plugin and the devices and attempted to set them up as new. No luck.
First I get ' RGB conversion for device update with error 'One or more of Hue/Saturation/Brightness is missing'
Then the plugin times out.
Error (client) timeout waiting for plugin response from com.autologplugin.indigoplugin.nanoleafcontroller for request UiAction
Error (client) timeout waiting for plugin response from com.autologplugin.indigoplugin.nanoleafcontroller for request GetUiDynamicList
Nov 10, 2020 at 1:55:25 AM
Error (client) received unexpected packet response UiAction (waiting for UiValidate)
Error (client) received unexpected packet response GetUiDynamicList (waiting for UiValidate)
Nov 10, 2020 at 1:55:57 AM
Nanoleaf Error Error in plugin execution UiAction:
File "plugin.py", line 885, in authoriseNanoleaf
File "/Library/Application Support/Perceptive Automation/Indigo 7.4/Plugins/nanoleaf.indigoPlugin/Contents/Server Plugin/nanoleaf/discover_nanoleaf.py", line 110, in generate_auth_token
File "/Library/Application Support/Perceptive Automation/Indigo 7.4/IndigoPluginHost.app/Contents/Resources/PlugIns/requests/api.py", line 111, in post
File "/Library/Application Support/Perceptive Automation/Indigo 7.4/IndigoPluginHost.app/Contents/Resources/PlugIns/requests/api.py", line 57, in request
File "/Library/Application Support/Perceptive Automation/Indigo 7.4/IndigoPluginHost.app/Contents/Resources/PlugIns/requests/sessions.py", line 477, in request
File "/Library/Application Support/Perceptive Automation/Indigo 7.4/IndigoPluginHost.app/Contents/Resources/PlugIns/requests/sessions.py", line 587, in send
File "/Library/Application Support/Perceptive Automation/Indigo 7.4/IndigoPluginHost.app/Contents/Resources/PlugIns/requests/adapters.py", line 493, in send
ReadTimeout: HTTPConnectionPool(host='192.168.86.142', port=16021): Read timed out. (read timeout=None)
