Nanoleaf Error Error in plugin execution MenuAction
Posted: Sat Mar 02, 2019 6:25 am
Any idea what is amiss?
- Code: Select all
Nanoleaf Error Error in plugin execution MenuAction:
File "plugin.py", line 131, in updatePlugin
File "/Library/Application Support/Perceptive Automation/Indigo 7.2/Plugins/nanoleaf.indigoPlugin/Contents/Server Plugin/ghpu.py", line 74, in update
File "/Library/Application Support/Perceptive Automation/Indigo 7.2/Plugins/nanoleaf.indigoPlugin/Contents/Server Plugin/ghpu.py", line 175, in _prepareForUpdate
File "/Library/Application Support/Perceptive Automation/Indigo 7.2/Plugins/nanoleaf.indigoPlugin/Contents/Server Plugin/ghpu.py", line 97, in getUpdate
File "/Library/Application Support/Perceptive Automation/Indigo 7.2/Plugins/nanoleaf.indigoPlugin/Contents/Server Plugin/ghpu.py", line 117, in getLatestRelease
File "/Library/Application Support/Perceptive Automation/Indigo 7.2/Plugins/nanoleaf.indigoPlugin/Contents/Server Plugin/ghpu.py", line 145, in _GET
File "/System/Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7/httplib.py", line 1053, in request
File "/System/Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7/httplib.py", line 1093, in _send_request
File "/System/Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7/httplib.py", line 1049, in endheaders
File "/System/Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7/httplib.py", line 893, in _send_output
File "/System/Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7/httplib.py", line 855, in send
File "/System/Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7/httplib.py", line 1274, in connect
File "/System/Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7/ssl.py", line 352, in wrap_socket
File "/System/Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7/ssl.py", line 579, in __init__
File "/System/Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7/ssl.py", line 808, in do_handshake
SSLError: [SSL: TLSV1_ALERT_PROTOCOL_VERSION] tlsv1 alert protocol version (_ssl.c:590)
