Nanoleaf Error Error in plugin execution MenuAction
Sat Mar 02, 2019 6:25 am
Busta999 offline
Any idea what is amiss?
 Nanoleaf Error                  Error in plugin execution MenuAction:
  File "plugin.py", line 131, in updatePlugin
  File "/Library/Application Support/Perceptive Automation/Indigo 7.2/Plugins/nanoleaf.indigoPlugin/Contents/Server Plugin/ghpu.py", line 74, in update
  File "/Library/Application Support/Perceptive Automation/Indigo 7.2/Plugins/nanoleaf.indigoPlugin/Contents/Server Plugin/ghpu.py", line 175, in _prepareForUpdate
  File "/Library/Application Support/Perceptive Automation/Indigo 7.2/Plugins/nanoleaf.indigoPlugin/Contents/Server Plugin/ghpu.py", line 97, in getUpdate
  File "/Library/Application Support/Perceptive Automation/Indigo 7.2/Plugins/nanoleaf.indigoPlugin/Contents/Server Plugin/ghpu.py", line 117, in getLatestRelease
  File "/Library/Application Support/Perceptive Automation/Indigo 7.2/Plugins/nanoleaf.indigoPlugin/Contents/Server Plugin/ghpu.py", line 145, in _GET
  File "/System/Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7/httplib.py", line 1053, in request
  File "/System/Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7/httplib.py", line 1093, in _send_request
  File "/System/Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7/httplib.py", line 1049, in endheaders
  File "/System/Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7/httplib.py", line 893, in _send_output
  File "/System/Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7/httplib.py", line 855, in send
  File "/System/Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7/httplib.py", line 1274, in connect
  File "/System/Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7/ssl.py", line 352, in wrap_socket
  File "/System/Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7/ssl.py", line 579, in __init__
  File "/System/Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7/ssl.py", line 808, in do_handshake
SSLError: [SSL: TLSV1_ALERT_PROTOCOL_VERSION] tlsv1 alert protocol version (_ssl.c:590)
Sat Mar 02, 2019 7:04 am
Re: Nanoleaf Error Error in plugin execution MenuAction
Are you running the latest version from the Indigo Plugin Store? v1.2.0 released on Feb. 9, 2019
Also, what version on macOS are you running?
Sat Mar 02, 2019 10:21 am
That pretty much says that they require TLS v 1.1 or 1.2 and that he is also not running High Sierra or later.
Specifically, it is an update checking failure in code that has now been removed in the latest plugin version (available in the Indigo Plugin store) for the very reason you have identified. :)
Sat Mar 02, 2019 11:03 am
Busta999 offline
No I was running a prior version - ironically I had used the Force Plugin Updater in Nanoleaf Plugin and it thought I had latest version as it did not update.
My bad ...
Running 10.12.6 on the Indigo Mac - change adverse for this machine :-)
Updated to latest and that seems to have fixed things.
In future I won't rely on the Plugin Updater and go straight to the Plugin Store to check for updates ..
