Errors/no ack
Sat Aug 11, 2018 11:17 am
Errors/no ack
Getting a lot of
   Nanoleaf Error                  Error in plugin execution ExecuteAction:
  File "plugin.py", line 910, in processSetEffect
NameError: global name 'action' is not defined
but only on the one that became a bit problematic when the motion detector beta bricked the Rhythm attached to it.
I'm also seeing the same Aurora drop connectivity, even though the Nanoleaf app can still communicate with it. I've done the typical stuff: restarted the plugin, power cycled the Aurora, and while either of these brings it back temporarily, I lose that connectivity again in a short period of time.
Any ideas on troubleshooting?
Sat Aug 11, 2018 11:49 am
autolog offline
Re: Errors/no ack
It's a bug trying to output an error message :oops:
Basically, it is trying to say that the "Set Effect" will be ignored as Aurora device is not connected. :)
I will fix this in due course but it shouldn't cause a problem other than taking up a few more lines in your indigo event log when compared to the message it was trying to output.
Not sure about the connectivity issue or why it should keep on losing the connection. The plugin will flag it as being not connected if it doesn't get a response from the nanoleaf.
Sat Aug 11, 2018 11:51 am
Re: Errors/no ack
Thanks. I'll keep poking at it.
