StandardError detected in 'updateDeviceState'. Line '310
Wed Nov 15, 2017 5:34 pm
Different Computers offline
   Nanoleaf Error                  StandardError detected in 'updateDeviceState'. Line '310' has error=''ProtocolError' object has no attribute 'reason''
that's a one off error from the log that hasn't recurred & doesn't seem to have stopped anything from happening, but I thought you would want to see it.
Thu Nov 16, 2017 5:33 am
Re: StandardError detected in 'updateDeviceState'. Line '310
Looks like it was a one-off error from the nanoleaf Aurora when requesting its status.
This error shouldn't occur where it did because at that point the Aurora has passed back a success code and therefore the error routines haven't been invoked. :?
If it happens again on a more regular basis, turn on full debugging and the debug logic will catch what is being returned and I can investigate further. :)
Sun Nov 19, 2017 7:17 am
I am still seeing these about 2x an hour.
Tricky to catch with full debugging because it happens at unpredictable times.
But maybe this helps?
Nanoleaf                        sent "Wall Art" Set Effect to Classic Visualizer
   Nanoleaf Error                  StandardError detected communicating with NANOLEAF lamp:
   Nanoleaf Error                  Traceback (most recent call last):
   Nanoleaf Error                    File "/Library/Application Support/Perceptive Automation/Indigo 7/Plugins/nanoleaf.indigoPlugin/Contents/Server Plugin/sendReceiveMessages.py", line 105, in run
   Nanoleaf Error                      success, statusMsg, self.globals['nl'][nanoleafDevId]["auroraInfo"] = self.globals['nl'][nanoleafDevId]["aurora"].info
   Nanoleaf Error                    File "/Library/Application Support/Perceptive Automation/Indigo 7/Plugins/nanoleaf.indigoPlugin/Contents/Server Plugin/nanoleaf/aurora.py", line 84, in info
   Nanoleaf Error                      return self.__get()
   Nanoleaf Error                    File "/Library/Application Support/Perceptive Automation/Indigo 7/Plugins/nanoleaf.indigoPlugin/Contents/Server Plugin/nanoleaf/aurora.py", line 37, in __get
   Nanoleaf Error                      errorMsg = e.args[0].reason.message.split('>: ')[1]
   Nanoleaf Error                  AttributeError: 'ProtocolError' object has no attribute 'reason'
