Feature request: Scene as device state
Sat Sep 23, 2017 10:09 am
Different Computers offline
Assuming it's on, is there any way to make the active scene the Aurora's device state? I'm thinking of some triggers that would be a lot simpler and run smoother if Indigo could know what scene is (or isn't) running on the device.
Right now it's just ON when a scene is running.
Sat Sep 23, 2017 11:50 am
Re: Feature request: Scene as device state
Unless I have misunderstood your requirement, you should be already able to do this? :)
The custom device state colorMode is either hs (hue saturation) or effects.
If it is effects , then you can check the custom device state effect which will be set to something like Northern Lights
All the custom device states are available to be checked when you set-up a trigger.
If this wasn't what you meant, could you elaborate further. :)
Sat Sep 23, 2017 12:49 pm
Well look at that! Exactly what I wanted. Never occurred to me to look there!
Just picked up a second Aurora and the whole initial setup for adding it to your network is MUCH better now. These guys at Nanoleaf are really on the ball. I was particularly impressed when I had to chase down a problem where my first Aurora was working with Indigo and not with their app. They never once tried to point fingers at Indigo, and dug really deep to find the problem and fix it.
Also, this plugin is totally awesome. :lol:
