Re: Nanoleaf Controller - Version 1.0.5 Available
Posted: Fri Jun 30, 2017 8:01 pm
Thanks... I'm going to reset it and try again..
Software Support and Home Automation Forum
https://forums.indigodomo.com/
Different Computers wrote:Somewhere between the plugin and my network, there's trouble.
- Code: Select all
Nanoleaf Error Discovering nanoleaf devices failed: Socket error while setting up discovery of nanoleaf devices!: [Errno 49] Can't assign requested address
The odd thing is that a few times, the plugin has found the device and it works for a while. But mostly not.
chasyori wrote:Thanks guys for your help... I finally got it working..
I did I a reset of it and now it's working like a charm...
after removing it from HomeKit and setting it up again, the plugin found the correct IP address.
Different Computers wrote:I think it’s safe to say that now, it has completely stopped working. All I get is a No ack status on the device. Is it possibly storing a bad IP address that the Aurora doesn’t actually have? The reason I did not suspect this until now is that when I restart the plug and it says it finds the Aurora.
Nanoleaf Error Discovering nanoleaf devices failed: Socket error while setting up host 'Unknown.domain' discovery of nanoleaf devices!: [Errno 49] Can't assign requested address
Nanoleaf Error Problem retrieving status for device 'Wall Art': Failed to establish a new connection: [Errno 61] Connection refused
Different Computers wrote:I really appreciate your plugging away at this, but still no joy with the 1.0.6:
- Code: Select all
Not sure I've seen "connection refused" before. Should I perhaps delete the device and re-add it?
Nanoleaf Error WARNING: IP Address changed for Nanoleaf 'Wall Art', it was '192.168.0.29' and is now '192.168.0.6' - Edit Device and Update IP Address.
howartp wrote:... Is it worth, based on your last update and reply to DC, automatically updating the stored IP address of your plugin nanoleaf device to that which you've discovered, now that you can detect mis-matches?
howartp wrote:Or, if not possible/practical, set the ui display state to say "mismatched IP" and enable error state (so it goes red) - this will prompt users to check log and find your nudging to update IP?
