Dynamic Control Plugin
Mon Sep 18, 2017 6:58 pm
Vig offline
Re: Dynamic Control Plugin
When I try to create a device I get the error messages on the picture. Also, when trying to disable it doesn't seem to gracefully go down. Any idea?
Error process (pid 620) failed to quit after polite request -- forcing it to quit now
Stopped plugin "Dynamic Control 1.1.0"
Indigo Cocoa client authenticated (172.16.32.151)
Error (client) timeout waiting for plugin response from com.bertmartin.DynamicButton for request CalcDeviceFunc
Error (client) timeout waiting for plugin response from com.bertmartin.DynamicButton for request UiGetValues2
Error (client) timeout waiting for plugin response from com.bertmartin.DynamicButton for request CallPluginFunc
Error (client) runDialogForDevice() caught exception: NSInvalidArgumentException -- *** -[__NSPlaceholderDictionary initWithObjects:forKeys:count:]: attempt to insert nil object from objects[0]
Error (client) received unexpected packet response CalcDeviceFunc (waiting for CallPluginFunc)
Screen Shot 2017-09-18 at 8.51.14 PM.jpg (289.93 KiB) Viewed 3996 times
Mon Sep 18, 2017 9:13 pm
bkmar1192 offline
Hmmmm.... haven't experienced that one before. Have you opened the configuration on the plugin itself (from the plugin's menu) and then saved it?
I'll take look at the code too and see if I can trace it.
Mon Sep 18, 2017 10:38 pm
Vig offline
I don't see that option:
Screen Shot 2017-09-19 at 12.36.49 AM.png (354.08 KiB) Viewed 3979 times
Tue Sep 19, 2017 8:44 am
bkmar1192 offline
Sorry, that is correct - I was thinking of one if my other plugins. I'll take another look tonight.
Thu Sep 21, 2017 9:55 pm
bkmar1192 offline
OK - the following post has some possible information. a couple things to try is to uninstall and reinstall Pillow. they also suggest installing pillow from within python. The three commands that are used are:
from PIL import Image
from PIL import ImageFont
from PIL import ImageDraw
So they should all be fine...
https://stackoverflow.com/questions/886 ... -named-pil
** Maybe someone on the board that knows Python a bit better than I can help :D
Sevilsivle wrote:
I followed all the instructions and installed Pillow.
This seems to have been successful, when I repeat the command I get:
Requirement already satisfied: Pillow in /Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7/site-packages
Requirement already satisfied: olefile in /Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7/site-packages (from Pillow)
However when I start the PlugIn I get the following error message in the Event Log:
Starting plugin "Dynamic Control 1.1.0" (pid 27455)
Dynamic Control Error Error in plugin execution InitializeMain:
File "plugin.py", line 13, in <module>
ImportError: No module named PIL
Stopping plugin "Dynamic Control 1.1.0" (pid 27455)
What is wrong here?
regards
Tim
Fri Sep 22, 2017 11:21 pm
Vig offline
Tried all kinds of uninstalls/installs, same error.. :?
Calling Image/ImageFont/ImageDraw from python/Indigo works though:
# /Library/Application\ Support/Perceptive\ Automation/Indigo\ 7/IndigoPluginHost.app/Contents/MacOS/IndigoPluginHost -i
Python 2.7.10 (default, Feb 7 2017, 00:08:15)
[GCC 4.2.1 Compatible Apple LLVM 8.0.0 (clang-800.0.34)]
Connected to Indigo Server v7.0.3, api v2.0 (localhost:1176)
I searched the forum for the errors I get and found couple threads with exact same messages but on different plugins, here is one of them mentioning the API call timeout:
viewtopic.php?f=212&t=18058&hilit=UiGetValues2&start=15#p135778
I will see if I can find another Mac to run the plugin as a test just in case if python is somehow broken. on my Indigo Server.
Sat Sep 23, 2017 10:49 am
bkmar1192 offline
What is odd is that there is really nothing much in my code that is running at that point and the device parameters file is pretty simple.
Couple of other things to try:
1. Check to see if the following directory exists. If it does not then manually create it. Maybe it is having a hard time setting up the directory.
/Library/Application Support/Perceptive Automation/Indigo 7/IndigoWebServer/plugins/DynamicButton/. This is the default it uses for saving images.
2. Delete the preferences file - in case it got corrupted during install.
a. Disable the plugin
b. In the directory: /Library/Application Support/Perceptive Automation/Indigo 7/Preferences/Plugins delete (or rename) the com.bertmartin.DynamicButton.indiPref file.
3. Total shot in the dark
a. Create a new device
b. Select "Dynamic Control" in type
c. Before selecting the "Model" uncheck the check box "Enable Indigo Communication"
d. Select the model.
Sat Sep 23, 2017 7:32 pm
Vig offline
Neither /Library/Application Support/Perceptive Automation/Indigo 7/IndigoWebServer/plugins/DynamicButton directory nor /Library/Application Support/Perceptive Automation/Indigo 7/Preferences/Plugins/com.bertmartin.DynamicButton.indiPref file exist. I created the directory manually, then disabled and removed the plugin and reinstalled it but getting the exact same errors.
Also, when I merely try to disable the plugin it's timing out:
Disabling plugin "Dynamic Control 1.1.0"
Stopping plugin "Dynamic Control 1.1.0" (pid 77552)
Error process (pid 77552) failed to quit after polite request -- forcing it to quit now
Not sure if it's even the plugin issue, probably the way API calls are handled in Indigo or some security issues in the OS preventing files/directories to be created (I am on the latest macOS 10.12.6)
Sat Dec 16, 2017 5:31 pm
tornado offline
Please see the PDF instructions in the download for details on installation and use.
I don't see the PDF in the download on GitHub. Was it removed?
Sat Dec 16, 2017 5:55 pm
tornado offline
I tried File:///Library/Application Support/Perceptive Automation/Indigo 7/IndigoWebServer/plugins/DynamicButton/heat1.png (which worked)
Use File://[path] and not http://[path]
This doesn't seem to work for me (file://) and I'm not sure why:
   Error (client)                  control page image URL invalid: File:///Library/Application Support/Perceptive Automation/Indigo 7/IndigoWebServer/plugins/DynamicButton/testDynamicControl.png
my directory:
tornado@MacMini DynamicButton $ pwd
tornado@MacMini DynamicButton $ ls
Sat Dec 16, 2017 6:11 pm
Different Computers offline
isn't it "file" not "File"?
FYI you can drag and drop the target file to get the correct path, but as I recall you still have to put the right prefix in front of it.
Sat Dec 16, 2017 7:05 pm
tornado offline
I've tried all permutations of File, file etc. I believe I have the path correct (if you compare the pwd output and what I have in my file:// area
thanks
Sat Dec 16, 2017 7:36 pm
Try replacing the spaces with '%20':
File:///Library/Application%20Support/Perceptive%20Automation/Indigo%207/IndigoWebServer/plugins/DynamicButton/testDynamicControl.png
URLs can't have spaces in them even though paths to files and folders can. With spaces, Indigo should still display the image on the control page even though it's (rightly) complaining about the URL construction.
Replace the spaces with %20; you'll get the image and no complaints from Indigo.
Mon Dec 18, 2017 5:13 pm
tornado offline
Thanks that worked. And for the record it did require me to use file:/// not File:///
Mon Dec 18, 2017 5:17 pm
Glad that worked for you. Sorry I didn’t spot the File vs file bit.
