PhotoFrame 1.2
Sat Jan 21, 2017 8:50 am
bkmar1192 offline
PhotoFrame 1.2
Photo Frame Plugin for Indigo
By Bert Martin
https://github.com/bkmar1192/PhotoFrame
This is a simple plugin that randomly grabs a single photo from a directory, and copies
it to a directory. It is designed to be used to create a photo frame as part of a
control page.
Photo Frame requires the Python Image Library module to be installed. To install
run the following from the terminal:
'sudo pip install Pillow' .
Plugin Configuration:
There is no configuration for the plugin itself.
Device Configuration:
Picture Directory: The directory where the pictures are retrieved from. Current Photo
Frame will only work with JPG images.
Destination Directory: Where the picture is copied to. The default is:
/Library/Application Support/Perceptive Automation/Indigo 7/IndigoWebServer/photoalbum/album.jpg
Group Photos: If this is checked, Photo Frame will display 10 photos from a similar time frame.
It will grab a random photo followed by the next nine images based on their file date.
Actions:
Toggle Photo Frame: This will toggle pausing the photo.
