Can not find thermostat
Posted: Fri Feb 15, 2019 12:57 pm
I have installed your plugin in a demo install of Indigo 7.2, and the plugin does not seem to be able to find the thermostat.
The interface with the AC and thermostat works fine and so does app access.
Any idea why the plugin is unhappy?
Any ideas would be appreciated.
This is the log entries from restart of plugin:
Enabling plugin "Honeywell Total Connect Comfort Thermostat 0.1.10"
Starting plugin "Honeywell Total Connect Comfort Thermostat 0.1.10" (pid 57210)
Honeywell Total Connect Comfort Thermostat MrSlim Plugin Init...
Started plugin "Honeywell Total Connect Comfort Thermostat 0.1.10"
Honeywell Total Connect Comfort Thermostat Number of thermostats found: 0
Honeywell Total Connect Comfort Thermostat the version of the plugin is up to date; version on server:0.1.10
Honeywell Total Connect Comfort Thermostat Error Error in plugin execution runConcurrentThread:
File "plugin.py", line 295, in runConcurrentThread
File "plugin.py", line 85, in _refreshStatesFromHardware
File "/Library/Application Support/Perceptive Automation/Indigo 7.2/Plugins/MrSlim.indigoPlugin/Contents/Server Plugin/MrSlim.py", line 373, in GetThermostat
File "/Library/Application Support/Perceptive Automation/Indigo 7.2/Plugins/MrSlim.indigoPlugin/Contents/Server Plugin/MrSlim.py", line 180, in parseThermostat
AttributeError: 'NoneType' object has no attribute 'getchildren'
Honeywell Total Connect Comfort Thermostat Error plugin runConcurrentThread function returned or failed (will attempt again in 10 seconds)
