Error in plugin
Sat Dec 22, 2018 5:11 pm
kennybroh offline
Error in plugin
Hi there-- So I got the gateway, set up one of my thermostats, and installed the plugin. It loaded and found my thermostat, but threw off this error:
File "plugin.py", line 234, in runConcurrentThread
AttributeError: 'Plugin' object has no attribute 'updateFrequency'
Mr.Slim Thermostat Error plugin runConcurrentThread function returned or failed (will attempt again in 10 seconds)
Mr.Slim Thermostat [Sat Dec 22 18:07:21 2018] Replacting Username/Password.
Mr.Slim Thermostat [Sat Dec 22 18:07:21 2018] Processed plugin preferences.
Mr.Slim Thermostat Number of thermostats found: 1
Mr.Slim Thermostat GREAT ROOM (id: 4534260)
Mr.Slim Thermostat Error Error in plugin execution runConcurrentThread:
I set it to zero but the error continues.
Thanks for taking a look at this.
T
Thu Dec 27, 2018 7:15 pm
kennybroh offline
Re: Error in plugin
Any luck?
Fri Dec 28, 2018 5:51 pm
mpoulson offline
Re: Error in plugin
Please upgrade to 1.8 to see if it fixes it.
Fri Dec 28, 2018 10:18 pm
kennybroh offline
Re: Error in plugin
Bingo-- that problem solved and log is now peaceful again! Thanks.
So this is what happens when you give someone an inch: As you know, the redlink interface not only allows mode and temperature to be set, it also allows fan speed. Any interest in adding this to the plug in?
Never hurts to ask...
Sat Dec 29, 2018 5:11 pm
mpoulson offline
Re: Error in plugin
I see they have a new API which is different than the one I normally use. I will see what it offers and determine how easy it will be to add new functionality.
Sat Dec 29, 2018 6:02 pm
kennybroh offline
Re: Error in plugin
Thanks. Not meaning to be greedy.... but you know how insatiable users can be! The good news is you are a user too.
Tue Jan 01, 2019 2:34 pm
mpoulson offline
Re: Error in plugin
I have updated to 1.9. This has support for FAN control for other TCC thermostats which offer this support.
If you have an existing device that support fan control (not a Mr Slim) you may have to delete and re-add the device to get the fan support to show.
