Light not working on Ring Floodlight
Wed Sep 05, 2018 9:31 am
brianmaas offline
I'm not sure when this stopped working, but I currently have v0.1.30 and I get this response when trying to turn on the light.
Sep 5, 2018, 8:27:33 AM
   Ring Doorbell                   Current state is "False"
   Ring Doorbell Error             send "Ring Floodlight" on failed
The light used to work just fine on an earlier version. Everything else is working. I can get updates when there is motion. I can download videos. It's fabulous.
Any ideas? I could try to install older versions of the plugin to see if I can get it work if that would be helpful. I do have telemetry and debugging on.
Brian
Thu Sep 20, 2018 8:36 pm
jguinn offline
Re: Light not working on Ring Floodlight
I can confirm the same behavior. Also using version 0.1.30. Just installed my floodlight this evening. The plugin is able to find the device, but does not appear to be able to obtain status updates from it or send status changes to it. Will be glad to help troubleshoot in any way I can.
Fri Oct 05, 2018 10:14 pm
jabeard3 offline
Good evening, same results here. I tried downgrading to .1.29 and .1.28 with the same results.
Mon Nov 05, 2018 9:45 am
abplus offline
Hi I'm having the same issue. I get a 'Send "Ringxxx" on failed.
Any further info on this please ?
Thanks.
Sat Nov 24, 2018 2:03 pm
abplus offline
Does anyone have an update on this ? Is it a Ring issue or the Plugin ?
Thanks.
Sun Dec 02, 2018 9:15 am
sullomforum offline
I am seeing the same results
Sat Apr 27, 2019 5:45 pm
sullomforum offline
Has anyone found a solution to this? I have tried reinstalling 1.30 but that doesn't have any impact.
Tue May 21, 2019 7:46 am
dz1rfj offline
Ring floodlights no longer working. Is ring perhaps trying to push us to buy their smart lighting by modifying an API or something ? HAs anyone had any contact with this plugin creator ? Thanks
