Ring Alarm support
Fri Jul 13, 2018 11:42 am
mpoulson offline
Ring Alarm support
The new versions of the Ring APIs added an extra level of encryption which prevents easy reverse engineering.
I am working on reverse engineering this further to try to add Ring Security support.
Wed Jul 25, 2018 9:26 pm
Venicenerd offline
Re: Ring Alarm support
Amazing. I would love you forever!!!!
Fri Nov 08, 2019 3:26 am
petematheson offline
Any update on this? I've just seen the UK launch of the ring alarm - would be very, very handy to get this integrating with Indigo!
Sun Nov 10, 2019 11:11 am
Jppaynesr offline
The posts here seem to indicate that this plugin is not working?
True?
I just downloaded it and it does not seem to be working for me. It is greyed out in the Devices list.
Here is the log file. ID numbers have been redacted.
Ring Doorbell Error Error in plugin execution startup:
File "plugin.py", line 129, in startup
File "plugin.py", line 132, in login
File "/Library/Application Support/Perceptive Automation/Indigo 7/Plugins/Ring.indigoPlugin/Contents/Server Plugin/Ring.py", line 80, in startup
File "/Library/Application Support/Perceptive Automation/Indigo 7/Plugins/Ring.indigoPlugin/Contents/Server Plugin/Ring.py", line 97, in refreshAuth
KeyError: key UserID not found in dict
Ring Doorbell the version of the plugin is up to date; version on server:0.1.30
Ring Doorbell Error Error getting events.
Ring Doorbell Error Reached max retry attempts. Won't Refresh from Server. !
Ring Doorbell Error You may need to contact Mike for support. Please post a message at http://forums.indigodomo.com/viewforum.php?f=235
Nov 10, 2019 at 11:57:35 AM
Ring Doorbell [Sun Nov 10 11:57:35 2019] Replacting Username/Password.
Ring Doorbell [Sun Nov 10 11:57:35 2019] Processed plugin preferences.
Ring Doorbell Number of devices found: 2
Ring Doorbell Front Door (id: ########)
Ring Doorbell Garage Door (id: #######)
Nov 10, 2019 at 11:58:50 AM
Wed Nov 13, 2019 3:48 pm
Interesting - https://github.com/asishrs/smartthings-ringalarm
Any way to get this ported across to an Indigo plugin somehow?
Looks like it makes the sensors / contacts visible to see motion / open / close info?
