Questions about plugin
Posted:
Thu Jun 14, 2018 12:41 pm
by emergent
So I installed the plugin, logged in and was able to add the device. However it doesn't show a state. I want to use it as a motion alarm to trigger a motion alarm through the homekit plugin. Is it not installed correctly?
Re: Questions about plugin
Posted:
Wed Jun 20, 2018 9:04 am
by emergent
Can anyone help with this? Do I need to make a virtual device or something?
Posted:
Wed Jun 20, 2018 6:51 pm
by mclass
You can find the device states in the UI by scrolling down in the small states window at the bottom panel when the device is selected - not obvious but it’s there!
I use a change in “last motion time” in a trigger to turn on external lights if it’s dark. No need for a virtual device! Seems to work OK, although with some delay due to the need for comms with the Ring server.
Good luck,
mclass
Posted:
Wed Jun 20, 2018 8:44 pm
by emergent
Wow. Thanks for that. That's not an area I've ever seen before. Forgive me for my questions, but is it possible to make a virtual on/off device with the motion sensor or ring status? I'm pretty new at this. I believe I would need that in order to import it into the Homekit Bridge plugin to act as a Homekit on/off motion sensor to pull up a video from my OTHER camera that is at my front door.
At least Ring has responded today and said that Homekit will be supported this fall, probably with the release of iOS12. Supposedly.
Posted:
Wed Jun 20, 2018 8:55 pm
by FlyingDiver
It might be even easier to use my Masquerade plugin
http://www.indigodomo.com/pluginstore/34/ to make a device that HomeKit will accept. It was pretty much designed to do exactly that.
Posted:
Wed Jun 20, 2018 9:00 pm
by emergent
Wow. That's perfect. Thanks so much. Again.
Posted:
Wed Jul 25, 2018 9:39 pm
by Venicenerd
Sorry, I am confused as well. I installed the plugin. Next I added a device:
- Screen Shot 2018-07-25 at 8.36.03 PM.png (52.03 KiB) Viewed 2792 times
And it shows up like this:
- Screen Shot 2018-07-25 at 8.36.38 PM.png (169.4 KiB) Viewed 2792 times
But I really don't know what to do with that. Is it supposed to show me any information? Also, here is the log:
- Screen Shot 2018-07-25 at 8.36.06 PM.png (45.83 KiB) Viewed 2792 times
Philipp
Posted:
Wed Aug 01, 2018 11:47 pm
by mpoulson
Well that is not good. I will debug this over the weekend.
