Error in plugin at startup
PostPosted: Sun Jan 01, 2017 10:58 am
by Asconasny
Hi
I get this when plugin starts.
Network Devices Error Error in plugin execution InitializeMain:
File "<string>", line 1, in <module>
File "plugin.py", line 55, in __init__
File "plugin.py", line 136, in _loadPluginPrefs
KeyError: key logLevel not found in dict
so it just quits
regards
Re: Error in plugin at startup
PostPosted: Sun Jan 01, 2017 2:20 pm
by jheddings
Hmmm... I hoped that the config screen would show before running __init__ (which was obviously a bad assumption). You should be able to get around this by going into the plugin configuration dialog and saving the default config. I'll also post a new version soon to try fixing the issue.
PostPosted: Sun Jan 01, 2017 3:07 pm
by jheddings
I think I found the issue... I was able to reproduce the error and built a fix. I've posted a new version of the plugin in the forum. You can also download using the link below. Thanks for trying out the plugin and for the bug report.
https://github.com/jheddings/indigo-netdev/releases/download/v2.0.3/Network-Devices-2.0.3.zip
PostPosted: Sun Jan 01, 2017 3:15 pm
by Asconasny
Great!
Works now.
Thank you
Regards
Asconasny
