Native Prowl Support for Indigo
Tue Apr 12, 2016 5:25 pm
auto_man offline
Re: Native Prowl Support for Indigo
Well, I did get version 4.2 running. I was able to successfully download and install 4.0, and then used the new auto update function to load 4.2. 4.2 is running now and all is well.
I'm using this Indigo-Prowl plugin to replace the my former Growl/Prowl setup. Very much simplified my setup.
Tue Apr 12, 2016 10:00 pm
jheddings offline
Excellent! Sorry the installation was a bit confusing... I need to spend more time on the documentation and simplified setup.
Let me know if you run into any issues!
Thu Dec 22, 2016 12:35 am
thumpinc offline
Is there a way to pass data in a variable to Prowl this way? I don't see any info to do that the way you can do using the GROWL notification plugin. Thanks!
Thu Dec 22, 2016 3:34 pm
jheddings offline
Yep... Variable substitution works in this plugin the same way other plugins do. Both the title and the message support standard device state & variable substitutions. The format is explained in the README file, which you can view by visiting the plugin page.
Wed Dec 28, 2016 1:14 pm
jheddings offline
This plugin has moved to a dedicated forum. Please look for updates or post questions there.
