Enphase Envoy-S Solar Power Plugin (with Panel Monitoring)
Mon Jun 15, 2020 3:14 pm
GlennNZ offline
Re: Enphase Envoy-S Solar Power Plugin (with Panel Monitorin
Hi
Sorry to hear about issues.
What envoy device have you got?
Will need a debug log from the plugin to have any idea as to what might be ongoing.
Turn on debug logging, check all the debug check boxes
Let it run for a bit and copy/paste/PM the results
Tue Jun 16, 2020 9:21 am
roquej offline
Sent you the details via PM.
Thank you!
JP
Thu Jun 18, 2020 4:41 am
GlennNZ offline
Hi
Thanks Check you PM - please send those through.
But basically have discovered there are 2 Envoy-S devices.
One metered, one unmetered.
It would appear (the PM results will help confirm) you have the unmetered one - this does not display the full production.json info. Instead we have to rely on the Legacy info source which doesn’t quite have as much details.
Hence the envoy-s device - fails.
The legacy device works and correctly reports.
And interestingly the panel devices created from the fail envoy-s work - as panel data in envoy-s unmetered still accessible.
A bit of mess really.
Will see if I re-rewrite the plugin with a new device covering all now known options, but leaving current devices alone. Just deprecated.
Glenn
Fri Jun 19, 2020 9:32 pm
GlennNZ offline
Hi
Sent a PM.
Need to know whether your version of Envoy-S reports anything at:
http://IPAddress/v1/api/consumption ?
Pending that information, have a new version on github
Checks for Metered/Unmetered Envoy-s Version and uses data from three sources.
Also pulls serial Number of device itself, so no longer needed to enter/find Serial Number for panels
Try the 0.2.6 version: from the clone/Download button
https://github.com/Ghawken/IndigoEnphaseEnvoy
Sun Jun 21, 2020 10:25 am
roquej offline
Glenn,
I tried the new version and is returning information. Seem correct.
JP
Mon Jun 22, 2020 9:28 pm
GlennNZ offline
Thanks - the consumption doesn't seem to be reported, hence the net power etc wrong.
Try plugin version 0.2.7
(Have sent a separate PM regarding a few other queries as try to search for Consumption reporting/data)
Glenn
