roquej wrote:Glenn,
Back on the error. I am getting now:
Enphase Envoy Plugin Error connecting to Device:Enphase Solar Error is:HTTPConnectionPool(host='192.168.XXX.XXX', port=80): Max retries exceeded with url: /production.json (Caused by ConnectTimeoutError(<requests.packages.urllib3.connection.HTTPConnection object at 0x113dae250>, 'Connection to 192.168.XXX.XXX timed out. (connect timeout=25)')
As mentioned, I am not on WiFI. Both the indigo server and Envoy are hardwired. This has worked without any issues for at least 18 months, so wonder what is causing this now.
I looked at everything and can't find any issues with the infrastructure. I use Unify switches and USG Pro 4. Can't see any error with the network.
JP
As last thread - I do occasionally see this. The enphase device web server hangs for hours. May be related to upgrade, or it doing something else? Not sure. You can manually power down and restart (which involves turning off power at fuse level) or wait it out. Normally comes back well under 24 hours.
If you go to the local enphase production webpage eg.
http://192.168.1.118/production.jsonThis is mine - it’ll will hang here to.
Could be any other number of network things, firewall, intrusion protection blocks/snort etc..
Glenn
