Have power-reset my Envoy-S, twice. However, I am still getting the following error:
Enphase Envoy Plugin Error connecting to Device:Enphase Solar
This has been happening for several weeks now
Any other suggestions?
JP
GlennNZ wrote:Glenn,Okay,
I am guessing that the above, not seen by others error has gone?
& we are back to a failure to connect happening occasionally?
Both of which likely reflect network/connection factors.
Presumably in between times everything is working?
The error is referring to a failure of a requests connection to the IP address of the setup enphase client. It has a massive 25 sec timeout.
Essentially it’s a very basic low level failure to connect to the device. A web browser, eg safari would have the same problem.
It may be a factor of connection to network, it may be other network factors (Wifi, strength, distance usual things).
Additionally the enphase-device web-browser does not like multiple communications with it. So if you have other things running, checking this enphase device the combination may increase the frequency of this connection error.
Glenn
roquej wrote:
I have gone crazy trying to find the root cause of this issue without success. The errors are disrupting solar power data, using Grafana, used to track the efficiency of the system.
To recap, I am getting this error dozens of times per day:
Enphase Envoy Plugin Error connecting to Device:Enphase Solar Error is:HTTPConnectionPool(host='192.168.X.X', port=80): Max retries exceeded with url: /production.json (Caused by NewConnectionError('<requests.packages.urllib3.connection.HTTPConnection object at 0x10a402c10>: Failed to establish a new connection: [Errno 51] Network is unreachable',))
roquej wrote:GlennNZ wrote:Glenn,Okay,
Glenn
All I can tell you is not my network. Why?
- Internet service: 1 GB Comcast business Internet (I work from home)
- Network equipment: All Unifi (UDM Pro router with rack mounted Unifi switches on a 1 GB backbone)
- No outbound firewall rules (getting 930+MB Internet throughput, with 9 ms ping latency, using different measurement tools, from the Indigo Mac Mini)
- Enphase is connected via CAT 6 cable directly into the same switch as the Mac Mini
- The problem only started with Indigo version 2021.1 and nothing changed with 2021.1.1. Indigo version 7.5 didn’t have this issue on the same equipment and internet service
- Nothing else is connected to the Enphase Envoy
- Running Indigo on Mac Mini 2014, CPU usage less than 25%
Therefore, the only conclusion, after eliminating all other possibilities, is that it must plugin related.
Makes sense?
JP
roquej wrote:If you turn debug logging on within the plugin config. And let it run for a bit. Then PM me the plugin.log found in the Event logs folder, in the Enphase directory. (Click the events log folder button top of the log window in indigo and find the enphase directory)I just remembered a difference in my configuration from 7.5. With 2021.1, I started tracking individual panel devices, of which I have 32.
Could that have caused the problem?
JP
