LTS camera (american company rebranded Hikvision) problems
Sat Dec 17, 2016 11:56 am
blysik offline
First, super excited about your plugin! I have a front door LTS camera, which generally acts like a Hikvision for everything, that I have Intrusion Alerts setup. When I set that camera up, I get this error:
Dec 17, 2016, 9:55:22 AM
   Disabling plugin "Hikvision 0.1.0"
   Stopping plugin "Hikvision 0.1.0" (pid 51953)
   Hikvision Debug                 Stopping concurrent thread
   Stopped plugin "Hikvision 0.1.0"
   Enabling plugin "Hikvision 0.1.0"
   Starting plugin "Hikvision 0.1.0" (pid 52449)
   Started plugin "Hikvision 0.1.0"
   Hikvision                       Your plugin version, v0.1.0, is current.
   Hikvision                       [Sat Dec 17 09:55:29 2016] Processed plugin preferences.
   Hikvision                       SSDP Listener Started...
   Hikvision Debug                 Starting device: Frontdoor Intrusion Alerts
   Hikvision Error                 exception in deviceStartComm(Frontdoor Intrusion Alerts): unsupported operand type(s) for +: 'NoneType' and 'str'
   Hikvision Debug                 Starting concurrent thread
   Hikvision                       Hikvision Reactor Ignition...
Later on I see it like this:
Dec 17, 2016, 9:49:58 AM
   Hikvision Debug                 Stopping device: Frontdoor Intrusion Alerts
   Hikvision Error                 Error in plugin execution ServerReplacedElem:
  File "/Library/Application Support/Perceptive Automation/Indigo 7/IndigoPluginHost.app/Contents/PlugIns/plugin_base.py", line 1175, in deviceUpdated
  File "plugin.py", line 41, in deviceStartComm
  File "/Library/Application Support/Perceptive Automation/Indigo 7/Plugins/Hikvision.indigoPlugin/Contents/Server Plugin/Hikvision.py", line 101, in deviceStartComm
  File "/Library/Application Support/Perceptive Automation/Indigo 7/Plugins/Hikvision.indigoPlugin/Contents/Server Plugin/Hikvision.py", line 188, in initCamera
TypeError: unsupported operand type(s) for +: 'NoneType' and 'str'
Any ideas? Thanks!
Sat Dec 17, 2016 12:04 pm
nlagaros offline
Re: LTS camera (american company rebranded Hikvision) proble
Did you configure the camera settings (ip address, port, username, password) in the device configuration dialog?
Sat Dec 17, 2016 12:07 pm
blysik offline
Yes. I've set IP, port, user, and pass. I'm trying to figure out how to add some debugging so I can see what "content" contains. It's an xml object, I guess? I'm wondering if my firmware has all the details you're looking for.
Sat Dec 17, 2016 12:15 pm
nlagaros offline
I see it now. Your camera is not reporting firmware version. Let me make a couple of adjustments. Stand by...
Sat Dec 17, 2016 12:17 pm
blysik offline
Here's the content.response:
   Hikvision Error                 <?xml version="1.0" encoding="UTF-8"?>
<DeviceInfo version="2.0" xmlns="http://www.std-cgi.com/ver20/XMLSchema">
<deviceName>Front door camera</deviceName>
<deviceID>23f8add8-6000-11b3-819a-bcad28192876</deviceID>
<deviceDescription>IPCamera</deviceDescription>
<deviceLocation>STD-CGI</deviceLocation>
<systemContact>STD-CGI</systemContact>
<model>CMIP8242W</model>
<serialNumber>CMIP8242W20160410BBWR588901848</serialNumber>
<macAddress>bc:ad:28:19:28:76</macAddress>
<firmwareVersion>V5.4.0</firmwareVersion>
<firmwareReleasedDate>build 160826</firmwareReleasedDate>
<encoderVersion>V7.3</encoderVersion>
<encoderReleasedDate>build 160616</encoderReleasedDate>
<bootVersion>V1.3.4</bootVersion>
<bootReleasedDate>100316</bootReleasedDate>
<hardwareVersion>0x0</hardwareVersion>
<deviceType>IPCamera</deviceType>
<telecontrolID>88</telecontrolID>
<supportBeep>false</supportBeep>
<supportVideoLoss>false</supportVideoLoss>
</DeviceInfo>
So it seems like it doesn't have some of the keys you're expecting to see?
Sat Dec 17, 2016 12:19 pm
blysik offline
I feel like this could be a camera config problem on my end. I'm a novice with this camera stuff.
Sat Dec 17, 2016 12:25 pm
nlagaros offline
It is a namespace issue - I'm specifically looking for Hikvision. I think I can figure this out using your debug output.
Sat Dec 17, 2016 12:26 pm
blysik offline
Awesome. Thanks!
Sat Dec 17, 2016 1:50 pm
blysik offline
That zip file contains version 0.1.0 I think.
Sat Dec 17, 2016 2:02 pm
nlagaros offline
I forgot to advance the version number. You can download again now.
Sat Dec 17, 2016 2:08 pm
blysik offline
Looks like it works! (Ignore the smtp error, my setup is probably wrong.)
Dec 17, 2016, 12:06:34 PM
   Trigger                         Frontdoor Camera Intruder
   Hikvision                       [Sat Dec 17 12:06:39 2016] Frontdoor Intrusion Alerts: IntrusionDetection OPEN
   DSC Alarm                       Alarm Zone 'Front Door' Closed.
   Hikvision Error                 [Sat Dec 17 12:06:41 2016] Cannot email alert, <class 'smtplib.SMTPException'>: Frontdoor Intrusion Alerts
   DSC Alarm                       Alarm Zone 'Front Door' Opened.
   Hikvision                       [Sat Dec 17 12:06:54 2016] Frontdoor Intrusion Alerts: IntrusionDetection CLOSED
This is WAY better than what I was doing, ie, using the Better Email plugin to watch for an email from my camera to trigger stuff.
Sat Dec 17, 2016 2:14 pm
blysik offline
And just to give you an idea of what I'm doing. I setup a trigger which watches for the device to change the 'Intrusion Detection' state to 'OPEN', and then it grabs a picture from the camera via the snapshot URL, and sends it via iMessage to me.
Looks like it works well! Thanks for the plugin!
Sat Dec 17, 2016 2:25 pm
nlagaros offline
Glad you are getting use from it. How are you doing the iMessage part of this?
Sat Dec 17, 2016 2:35 pm
blysik offline
It's a shell script that runs AppleScript:
#!/bin/bash
curl -s http://user:pass@192.168.55.218/Streaming/channels/1/picture > /tmp/8.jpg
osascript <<EOD
tell application "Messages"
set targetBuddy to "+PHONENUMBERHERE"
set targetService to id of 1st service whose service type = iMessage
set myFile to "/tmp/8.jpg"
set DestFile to (POSIX file myFile) as string
send file DestFile to buddy targetBuddy of service id targetService
end tell
EOD
The mac this runs on is logged into an Apple iMessages account already and has iMessages open.
