Hikvision Camera Plugin
Sat Dec 17, 2016 9:52 am
nlagaros offline
This plugin subscribes to the Hikvision IP surveillance API alert stream and is compatible with most v2 network cameras. I’ve tested this with the 2CD2032 and 2CD2342 but should work with all cameras in this series.
I wanted a quick and dirty way to get alerts in Indigo as well as send a still image when certain alerts are fired.
Plugin Home Page: http://vulture.lagaros.com:8000/wordpress/hikvision-cameras/
Plugin Configuration: http://vulture.lagaros.com:8000/wordpress/hikvision-cameras/hikvision-configuration/
Direct Download: https://vulture.lagaros.com/IndigoPlugins/Hikvision/Hikvision.indigoPlugin_0.1.0.zip
Sat Dec 31, 2016 4:40 pm
nlagaros offline
Hikvision Camera Plugin v0.1.2
v0.1.2 – 12/31/2016
  • Softened restart of streams to attempt re-connect every minute if the TCP socket is broken by the camera.
  • Internalized import of ElementTree library that is packaged with Python 2.7.
  • Added action to reboot camera.
  • Added action to enable/disable alerts from camera.
Download here: http://vulture.lagaros.com:8000/wordpress/hikvision-cameras/
Sun Jan 08, 2017 9:51 am
nlagaros offline
Hikvision Camera Plugin v0.1.3
v0.1.3 – 01/08/2017
  • Additional logic to properly close streams upon error.
  • Added action to email snapshot from camera at will.
Download here: http://vulture.lagaros.com:8000/wordpress/hikvision-cameras/[/quote]
Sat Feb 04, 2017 5:04 pm
nlagaros offline
Hikvision Camera Plugin v0.1.4
v0.1.4 - 02/04/2017
  • Timeout now set for establishing alert streams.
  • Will connect to SMTP servers with no authentication.
  • Configurable subject allowed for email snapshots.
