Proliphix™ Plugin Discussion
Mon Jun 25, 2012 12:51 pm
Re: Proliphix™ Plugin Discussion
I think that discussion was just about increasing the delay between retries after consecutive failures.
But other than that the plugin needs to handle/fix the situation since there is no way for Indigo to know if it is a transient issue that might go away (network or hardware connectivity problem), or a bug that will just repeat indefinitely.
Mon Jun 25, 2012 1:02 pm
berkinet offline
Well, in the specific case of the Proliphix plugin, it is clearly a bug because of an unanticipated state. Since the beta testers all had conforming tstats, and I forgot to code for the possibility, there is a bug.
So, are you suggesting that a plugin could (should?) watch for something like being called to often and find a way to die gracefully - with some appropriate messaging to the log? I think the was also another discussion a few months back about allowing a plugin to just exit. But, the issue was with Indigo trying to restart it. How would you go aout this?
Mon Jun 25, 2012 1:18 pm
You should add exception handlers around the contents of your entire runConcurrentThread code, and handle all exceptions there appropriately.
The plugin isn't catching the exceptions apparently so it is throwing out of that function and all Indigo can do is hope that it is a temporarily problem and restart it. If you handle the exceptions in the plugin you can decide in the handlers what should happen: silently retry, log an error, disable the plugin, etc. But that is 100% the plugins responsibility since it is the only one that can know how to properly handle the errors.
If you do have a fatal exception and want to catch it and stop the plugin, then to do so you can use this method:
self.stopPlugin("had to stop the plugin because something bad happened!", isError=True)
But be careful that you don't call it for transient problems since plugins should try to auto-recover from those. For example, you wouldn't want a plugin to be stopped just because your ISP connectivity goes down for a few minutes.
Mon Jun 25, 2012 5:08 pm
The main issue with the plugin is that it seems to assume that there's one or more devices. That of course is a bad assumption - when the plugin first starts up there definitely won't be a device. That causes the first while loop in runConcurrentThread to spin forever. It looks like it shouldn't be logging the "Creating Proliphix Thermostat device list" since I didn't change anything in the plugin config (and i think it's supposed to default to 0) so there's another little buglet there of some type.
In fact, I'm really unclear what that while loop is accomplishing - it seems rather useless since it won't get called for devices that get added after the plugin starts up...
Mon Jul 09, 2012 10:51 pm
ds10 offline
I'm using the beta plugin. I have two NT-20e thermostats and one NT-10e. Several issues seen:
1) as others reported, upon enabling the plugin the event log shows a constant: "Proliphix Plugin Creating Proliphix Thermostat device list".
2) I try to add a thermostat device. Fill out the Create New Device. Upon completion, I get a beep when hitting OK. Seems odd, no message to go with the beep. Log shows: " Proliphix Thermostat Control Debug Validate: The tstat address is: http://192.168.5.32:80/get?OID1.2=&OID2.7.1=
Proliphix Thermostat Control Debug Validate: OIDs returned... raw: 1.2=upstairs&2.7.1=NT20&, processed: ['1.2', 'upstairs', '2.7.1', 'NT20', '']
" which looks OK.
3) Hit OK one more time. Device now added, but showing no useful data (all dashes or zeros). And this in the logs:
Proliphix Thermostat Control Error Error in plugin execution runConcurrentThread:
File "plugin.py", line 247, in runConcurrentThread
<type 'exceptions.KeyError'>: key ShowCoolHeatEquipmentStateUI not found in dict
Proliphix Thermostat Control Error plugin runConcurrentThread function returned or failed (will attempt again in 10 seconds)
Proliphix Thermostat Control Debug Starting concurrent thread
Proliphix Thermostat Control Debug Added device Id 1825110916 to device list
repeats forever.
Could use some help on what to do from here. Happy to test new code if desired.
Wed Jul 11, 2012 12:51 pm
berkinet offline
It is going to be a few days until I can get to this. I am out of the US for a while and do not have access to my regular development setup. However, it sounds like a problem in the Python dictionary in the app which contains the Proliphix MIB.
Wed Nov 07, 2012 10:07 pm
ds10 offline
Just curious if you'll be getting back at this code.
Thu Nov 29, 2012 12:18 pm
berkinet offline
@ds10 can you verify you are running v 1.9.2. If not, please update. The plugin is available on dropbox.
Mon Mar 11, 2013 2:47 pm
asw24b offline
By any chance have you had a chance to add any more features ?
I wanted to check before I implemented fan control myself....
Thanks !!!
Mike
Mon Mar 11, 2013 3:15 pm
berkinet offline
I have not used the fan control since my heating system does not support it. But, it should work. I an look at this in a week when I am back from traveling.
Sun Mar 24, 2013 6:32 pm
ethanw offline
Re: Proliphix™ Thermostat plugin V2.0 teaser
Hey berkinet I have this Proliphix™ Thermostat plugin installed but this is not the same view I get? Same view as your picture.
Any ideas?
berkinet wrote:
Now that Matt and Jay have released Indigo 5.0.3, I am in the process of upgrading the Proliphix plugin to provide complete support of the Indigo Thermostat UI. I.e. just like a Venstar (but better).
I have a solid alpha working here and just need to tweak a few things before releasing this as a 2.0 beta. In the meantime, pictures speak louder than words, so...
Sun Mar 24, 2013 7:24 pm
berkinet offline
Make sure you are using the latest beta 2.b1. It is available on dropbox.
Mon Mar 25, 2013 9:11 am
asw24b offline
When I click on your link, it downloads v. 1.9.1. Is the version string just incorrect ?
Thanks !
Mike
Mon Mar 25, 2013 9:33 am
Dewster35 offline
Indigo doesn't like the "b" in the plugin name. You have to do a lot of work around to get it to update to the latest plugin version. Simply double clicking on the file doesn't install it properly.
Mon Mar 25, 2013 9:55 am
asw24b offline
Yes.
I just opened the bundle and read the release notes; It says that 1.9.1 == 2.0bx
2 fixes needed:
line 247:
self.thermCap[tstat.id] = {'NumHumidityInputs': tstat.pluginProps["NumHumidityInputs"], 'NumTemperatureInputs': tstat.pluginProps["NumTemperatureInputs"], 'ShowCoolHeatEquipmentStateUI': tstat.pluginProps["ShowCoolHeatEquipmentStateUI"]}
Throws an error because ShowCoolHeatEquipmentStateUI is commented out of the devices.xml file.
and
line 528:
actionStr = _lookupActionStrFromHvacMode(actionMode)
needs to be:
actionStr = _lookupActionStrFromHvacMode(action.actionMode)
Thanks !
Mike
