Phidgets Plugin Discussion
Mon Feb 17, 2020 6:53 am
hamw offline
Re: Phidgets Plugin Discussion
I’ll take a look, but it is a new machine with a clean install of the operating system and each application newly installed individually. No other issues as far as I can tell.
Mon Feb 17, 2020 7:26 am
berkinet offline
I suspect the Launch Daemon never got installed, or wasn't enabled. Check to see you have /Library/LaunchDaemons/com.phidgets.webservice21.plist
Mon Feb 17, 2020 9:01 pm
hamw offline
Yes, thanks for the suggestion. Here's the contents of the plist:
<!DOCTYPE plist PUBLIC "-//Apple Computer//DTD PLIST 1.0//EN" "http://www.apple.com/DTDs/PropertyList-1.0.dtd">
<plist version="1.0">
<dict>
   <key>Label</key>
   <string>com.phidgets.webservice21</string>
   <key>ProgramArguments</key>
   <array>
      <string>/usr/local/bin/phidgetwebservice21</string>
      <string>-p</string>
      <string>5001</string>
   </array>
   <key>RunAtLoad</key>
   <true/>
</dict>
</plist>
The phidgets22 plist was also still in there, so I deleted it. Maybe that will make a difference.
Tue Feb 18, 2020 2:53 am
berkinet offline
... ...The phidgets22 plist was also still in there, so I deleted it. Maybe that will make a difference.
If the plist is there, it should start. Are you are sure you checked Start Automatically in the Phidgets Web Service preference pane? Assuming you have checked the auto-start option, try these steps...
Enter the following command in a terminal window:
launchctl list |grep phidget
If that returned something, post it here. If it returned nothing, try this next:
launchctl load /Library/LaunchDaemons/com.phidgets.webservice21.plist
and then try the first command again. If it succeeds this time then issue this command
launchctl start com.phidgets.webservice21
and see if the web service has started. If it didn't start, enter this command and post any results back here:
 grep phidget /var/log/system.log
Tue Feb 18, 2020 9:36 pm
hamw offline
Thanks, Berkinet. I turned off the WebService, and the commands would not launch it. Here's the results of your suggestions.
  [Restored Feb 14, 2020 at 7:21:20 PM]
Last login: Fri Feb 14 19:21:17 on console
Restored session: Fri Feb 14 19:20:33 EST 2020
Hamiltons-Mac-mini:~ hamilton$ launchctl list |grep phidget
Hamiltons-Mac-mini:~ hamilton$ launchctl load /Library/LaunchDaemons/com.phidgets.webservice21.plist
-   1   com.phidgets.webservice21
/Library/LaunchDaemons/com.phidgets.webservice21.plist: service already loaded
Hamiltons-Mac-mini:~ hamilton$  grep phidget /var/log/system.log
Feb 18 22:32:05 Hamiltons-Mac-mini com.apple.xpc.launchd[1] (com.phidgets.webservice21[74685]): Service exited with abnormal code: 1
Appreciate your thoughts.
Wed Feb 19, 2020 5:15 am
berkinet offline
hamw wrote:
... launchctl load /Library/LaunchDaemons/com.phidgets.webservice21.plist
...grep phidget /var/log/system.log
...(com.phidgets.webservice21[74685]): Service exited with abnormal code: 1
[/code]
Well, based on the last line, we can see the service did not start. However, you executed the launchctl load command twice. The second command should have been launchctlstart
Try just doing a load, then the start, and then the grep again.
Wed Feb 19, 2020 8:36 pm
hamw offline
Thanks; here's what it resulted.
Hamiltons-Mac-mini:~ hamiltonwilliams$ launchctl start com.phidgets.webservice21
Hamiltons-Mac-mini:~ hamiltonwilliams$ launchctl list |grep phidget
-   -11   com.phidgets.webservice21
Hamiltons-Mac-mini:~ hamiltonwilliams$ launchctl load /Library/LaunchDaemons/com.phidgets.webservice21.plist
Hamiltons-Mac-mini:~ hamiltonwilliams$  grep phidget /var/log/system.log
Feb 19 21:27:49 Hamiltons-Mac-mini com.apple.xpc.launchd[1] (com.phidgets.webservice21[37984]): Service exited due to SIGSEGV | sent by exc handler[37984]
Feb 19 21:30:35 Hamiltons-Mac-mini com.apple.xpc.launchd[1] (com.phidgets.webservice21[38131]): Service exited due to SIGSEGV | sent by exc handler[38131]
Feb 19 21:33:12 Hamiltons-Mac-mini com.apple.xpc.launchd[1] (com.phidgets.webservice21[38331]): Service exited due to SIGSEGV | sent by exc handler[38331]
Feb 19 21:33:51 Hamiltons-Mac-mini com.apple.xpc.launchd[1] (com.phidgets.webservice21[38340]): Service exited due to SIGSEGV | sent by exc handler[38340]
Thu Feb 20, 2020 5:26 am
berkinet offline
hamw wrote:
... Service exited due to SIGSEGV | sent by exc handler[37984]
[/code]
Well, that is the error that is causing the auto loading of the phidgets web service to fail. Unfortunately, I have no idea what is causing it. Even odder is that it starts when you do it manually from the pref pane.
It is probably a permissions problem, so you might want to run the disk utility and run First-Aid on the disk. If that doesn't fix it, I'd contact Phidgets. But, one thing is clear, there is definitely something wrong on your installation.
Fri Feb 28, 2020 3:19 pm
landry offline
Hi Birkinet
I have a new Mac mini and I am am in the same boat as hamw. The latest Mac software for Phidgets is only 22 libraries and Brian Burley at Phidgets has suggested installing the 21 libraries from this site:
https://www.phidgets.com/downloads/phid ... s/Phidget/
I tried and can't get past the malware security and Brain has no suggestions how to remedy this. I think phidgets.com is abandoning the 21 libraries starting with the new Mac OS 10.11+ software. I'll keep working on him. My twos sbsc3's are less than three years old.
Any suggestions how to install past the Mac security?
Fri Feb 28, 2020 3:39 pm
landry offline
Birkinet
Never mind I finally got phidgets 21 installed ad its up and running!! Dont know how i got around malware warning I wish i could recorded what I did. i think I left security unlocked and open and rebooted mac and then I got the llibraies installed!! i was just persistent!
Sat Feb 29, 2020 2:51 am
berkinet offline
landry wrote:
Hi Birkinet
I have a 0ew Mac mini and I am am in the same boat as hamw. ... ...I tried and can't get past the malware security and Brain has no suggestions how to remedy this. I think phidgets.com is abandoning the 21 libraries .. ...
I am glad you got this fixed. I really don't know what I could have added to help. I have the 21 libs running on MacOS 10.15.3 on a 2018 Mac Mini without issue. I suspect your problems had something to do with your firewall or security settings. But, without being able to duplicate the problem, that would just be a guess.
Phidgets have dropped support for the 21 libs, but they will continue to be available. In the meantime, if all goes well I may have a 22 plugin sometime in Spring.
Sat Feb 29, 2020 4:43 pm
hamw offline
Berkinet, great news on perhaps a new plugin. I will hold on adding anything to the system until we hear back.
Mon Jun 22, 2020 12:21 pm
mpleeds offline
I am currently using an Easydaq USB8VI4DIOSR (8 isolated inputs + 4 relays + 4 DIO channels) Digital I/O to perform 2 tasks:
1. Reading the analog gallon counters on my house and irrigation meters. These are hardwired to my office, so no ethernet or wifi is necessary.
2. Indigo controls Easydaq relays to turn well valve actuators on / off, also hardwired.
As the Easydaq card seem to be malfunctioning and may require replacement, I am entertaining the possibility of switching over to Phidgets. In addition, I am currently using a wireless BBQ thermometer to broadcast (using RFXCOM RFXTRX433E) temperature changes from my sauna to regulate heater control, but would prefer a hardwired solution. Phidgets has a number of external K-type or RTD (highly accurate) probes which may be suitable for this purpose.
Not having time to read every post on this informative discussion thread, it would be great to know if these tasks could be accomplished via Phidgets and Plugin, as well as any other recommendations / incompatibility warnings.
Merrill
