Re: Phidgets Plugin Discussion
Posted: Sun Mar 10, 2019 10:18 am
Just finally trying to figure out why Indigo can no longer see my phidget boards. I have two boards and neither f them are connecting in Indigo and yes I have changed the serial number in the configuration setting
It is clearly visible in the Bonjour tab of the preference pane.
I have deleted everything out of indigo. I have even removed the plugin, downgraded the plug in to no avail. I'm back at the most recent version 0.7.4 with the same results. When I attempt to add the interface kit I'm still getting the same errors:
So the phidget board appears as offline in my devices window in indigo. I can go into the setting and when I select ifKit Config I get this:
Just a note that it ran fine on Mac OS 10.8.5 (Mountain Lion). It has not worked since I upgraded to High Sierra,
- Code: Select all
Phidgets Plugin ifKit IfKit thread run() opened the Phidget device new device
Phidgets Plugin deviceStartComm: Added type:ifKit, name:new device, serial:407470
Phidgets Plugin exiting deviceStartComm with:[<_MainThread(MainThread, started 140735900545920)>, <ifkit(Thread-2, started 123145324974080)>]
Phidgets Plugin Error interfaceKit: Could not attach to device new device. It has been set to offline
Phidgets Plugin Entering didDeviceCommPropertyChange for device: new device (1459536840 - ifKit)
Phidgets Plugin didDeviceCommPropertyChange: No plugin property changes for: ifKit new device
- Code: Select all
Phidgets Plugin readIfKitConfig typeId:
ifKit
Phidgets Plugin readIfKitConfig devId:
1459536840
Phidgets Plugin No existing ifkit found. Creating new ifkit
Phidgets Plugin Opening ifkit....
Phidgets Plugin calling openRemoteIP (ip=127.0.0.1 , port=5001)
Phidgets Plugin calling openRemoteIP completed (ip=127.0.0.1 , port=5001)
Phidgets pre waitForAttach (ip=127.0.0.1 , port=5001)
Error (client) timeout waiting for plugin response from com.perceptiveautomation.indigoplugin.Phidgets for request UiAction
Error (client) received unexpected packet response UiAction (waiting for GetUiDynamicList)
Phidgets Execption raised on waitForAttach (ip=127.0.0.1 , port=5001)
Phidgets Plugin Error Phidget Exception b (ip=127.0.0.1 , port=5001) 13: Given timeout has been exceeded.
Phidgets Plugin Error Phidget Exception d (ip=127.0.0.1 , port=5001) 5: Phidget not physically attached.
Phidgets Sensors:0, inputs:0, outputs:0
Phidgets Plugin New ifkit closed
Phidgets Plugin ifkit read was successful
Phidgets Plugin readIfKitConfig valuesDict returned: UiValuesDict : (dict)
