Phidgets Plugin Discussion
Tue May 14, 2013 9:27 am
daz offline
Re: Phidgets Plugin Discussion
hamw wrote:
I wrote up the install here. Overall it went pretty smoothly.
Following Berkinet's advice I used one of the digital inputs on the 8/8/8 board to count the pulses, and it works! As the meter spins the little dial rotates under the sensor and sends a pulse to the Phidgets board. The pulse is incremented with a trigger into a variable. So, no frequency counter required (yaay! total project cost is now $75 bucks cheaper!!).
There are a couple of things I'd like to do:
1. Total up historical water usage on a current day, prior day, current week, prior week, current month, and all months prior for one year (and maybe two or three?).
2. Use the pulse info to determine if there is a leak. It seems like water intensive things could create false calls, for instance running a bath or washing a car. I'm thinking that using the occupancy sensors (SPR, FMF, alarm status) during the day to determine if someone is home and suppressing a trigger would account for most of these events - I don't think my wife will allow motion detectors in the bathrooms! Then, monitoring strictly for any flow when everyone is away, and at night when everyone is asleep might pick up slow leaks.
I think both of these could be done with Applescript and some triggers. I am OK with AS but am not sure how to get time dependent things like current day, prior day, current month, prior month etc into a script. But, this reporting is very similar to what the RFXcom plugin's Rain Sensor already does. If anyone has suggestions how to write such a script I'd be very appreciative.
Nice write up :)
Wed May 15, 2013 8:27 pm
hamw offline
daz, appreciate the post! :D
I think I figured it out. Each "current variable", for instance Today, This Week and This Month, are incremented each time the water meter clicks via a single trigger. Every day at 12:01 AM a schedule runs the following script:
      set {year:y, month:m, day:d, weekday:w} to (current date)
--Today and Yesterday. Second line in each sequence resets the current variable to ""
set value of variable "WaterUse_2_Yesterday" to value of variable "WaterUse_1_Today" as string
set value of variable "WaterUse_1_Today" to ""
--This week and last week
if w is Monday then
   set value of variable "WaterUse_4_LastWeek" to value of variable "WaterUse_3_ThisWeek"
   set value of variable "WaterUse_2_Yesterday" to ""
end if
--This month and last month
if d is 1 then
   set value of variable "WaterUse_6_LastMonth" to value of variable "WaterUse_5_ThisMonth"
   set waterUseThisMonth to value of variable "WaterUse_5_ThisMonth"
   set value of variable "WaterUse_5_ThisMonth" to ""
end if
--Prior Month historical data
if d is 1 then
   if m is January then
      set value of variable "WaterUse_18_Dec" to waterUseThisMonth
   end if
   if m is February then
      set value of variable "WaterUse_7_Jan" to waterUseThisMonth
   end if
   if m is March then
      set value of variable "WaterUse_8_Feb" to waterUseThisMonth
   end if
   if m is April then
      set value of variable "WaterUse_9_Mar" to waterUseThisMonth
   end if
   if m is May then
      set value of variable "WaterUse_10_Apr" to waterUseThisMonth
   end if
   if m is June then
      set value of variable "WaterUse_11_May" to waterUseThisMonth
   end if
   if m is July then
      set value of variable "WaterUse_12_Jun" to waterUseThisMonth
   end if
   if m is August then
      set value of variable "WaterUse_13_Jul" to waterUseThisMonth
   end if
   if m is September then
      set value of variable "WaterUse_14_Aug" to waterUseThisMonth
   end if
   if m is October then
      set value of variable "WaterUse_15_Sep" to waterUseThisMonth
   end if
   if m is November then
      set value of variable "WaterUse_16_Oct" to waterUseThisMonth
   end if
   if m is December then
      set value of variable "WaterUse_17_Nov" to waterUseThisMonth
   end if
end if
Honestly, this is probably not very elegant. If anyone can show me how to write this in a less "brute force" way, I'd appreciate seeing how it's done. I will work on the "sensing" stuff.
Mon May 20, 2013 5:14 am
loafbread offline
Indigo Beta 8 causes a lot of Phidgets errors in the log. The IO seems to be working but here is a sample of the errors when operating a Digital Output on a 0/0/8 board attached to an SBC. Phidgets plugin v0.5.3.
Phidgets ifKit digital output read finished update for index 0
Phidgets Error Error in plugin execution ServerReplacedElem:
File "/Library/Application Support/Perceptive Automation/Indigo 6/IndigoPluginHost.app/Contents/PlugIns/plugin_base.py", line 800, in deviceUpdated
File "plugin.py", line 326, in didDeviceCommPropertyChange
File "/Library/Application Support/Perceptive Automation/Indigo 6/Plugins/Phidgets.indigoPlugin/Contents/Server Plugin/ifkit.py", line 224, in readDigitalOutput
<type 'exceptions.UnboundLocalError'>: local variable 'inValue' referenced before assignment
Phidgets ifKit Setup for device "Phidgets 0/0/8 " complete, listening for events
Phidgets ifKit digital output read finished update for index 1
Phidgets ifKit digital output read finished update for index 2
Phidgets ifKit digital output read finished update for index 3
Phidgets ifKit digital output read finished update for index 4
Phidgets ifKit digital output read finished update for index 5
Phidgets ifKit digital output read finished update for index 6
Phidgets ifKit digital output read finished update for index 7
Mon May 20, 2013 9:02 am
Hi Richard:
I think this problem is occurring because now the deviceUpdated() callback is called more frequently, which then calls the plugin's override of the didDeviceCommPropertyChange() method. I suspect that inside the override it is then referencing variables/instances that haven't yet been created.
Note that deviceUpdated() can be called now before a device's ConfigUI has been shown or validated (placeholder devices are created and inserted into the database before the UI is shown in Indigo 6). You can check if the device is configured yet by testing the dev.configured attribute. So you'll probably want to add a conditional at the top of didDeviceCommPropertyChange() that checks if that is False, in which case it returns out.
Additionally, deviceUpdate() is now also called when states are updated by the plugin. Previously there was a buglet that prevented the callback in that particular case.
Mon May 20, 2013 4:43 pm
jsrivet offline
I had the same problem and I have the solution. You have to go disabled line 299 to 326 of file plugin.py. in the file phidget.indigo.pluing
    # def didDeviceCommPropertyChange(self, origDev, newDev):
        #if self.logLevel > 1:
            #indigo.server.log(u"Entering didDeviceCommPropertyChange for device: %s (%d - %s)" % (newDev.name, newDev.id, newDev.deviceTypeId))
        #if newDev.deviceTypeId == "ifKit" or newDev.deviceTypeId == "phStandalonePhidget" or newDev.deviceTypeId == "phLcdScreen":
            # If this is a standalone device, make sure it gets restarted on any changes
            #return True
        #elif newDev.deviceTypeId == 'phIfKitSensor':
            # This is an analog sensor -- Nothing to restart, put we should re-read the index value
            #ifKitDevId = int(newDev.pluginProps['phSensorIfKitId'])
            #ifKitDevIndex = int(newDev.pluginProps['phSensorIfKitAnalogInput'])
                #indigo.server.log(u"Sensor attached to dev num: %s" % ifKitDevId)
            #self.phThreadDict[ifKitDevId].readSensorInput(ifKitDevIndex)
        #elif newDev.deviceTypeId == 'phDiIfKit':
          # This is a digital input -- Nothing to restart, put we should re-read the index state
            #ifKitDevId = int(newDev.pluginProps['phDiIfKitId'])
            #ifKitDevIndex = int(newDev.pluginProps['phDiIfKitInput'])
                #indigo.server.log(u"Digital Input on dev num: %s" % ifKitDevId)
            #self.phThreadDict[ifKitDevId].readDigitalInput(ifKitDevIndex)
        #elif newDev.deviceTypeId == 'phDoIfKit':
            #ifKitDevId = int(newDev.pluginProps['phDoIfKitId'])
            #ifKitDevIndex = int(newDev.pluginProps['phDoIfKitOutput'])
            #self.phThreadDict[ifKitDevId].readDigitalOutput(ifKitDevIndex)
        return False
Mon May 20, 2013 11:39 pm
berkinet offline
I am on the road for a couple of weeks. Until I can get back, to make the changes noted by Matt, you can follow jaruvet's advice.
Mon May 27, 2013 11:10 am
midd offline
Well I just read all 10 pages of this thread and have a few questions. Would love to use the Vegetronix soil moisture sensors in my yard. I would obviously need the Phidget 1048 device. Would I need anything else other than the plug in?
Indigo 7, Monterey (12.1) on a 2009 Mac Pro..
Mon May 27, 2013 12:17 pm
berkinet offline
If I understand the Vegetronix sensors, they output a voltage between 0 and 3vdc proportionate to moisture or temperature. If that is the case, rather than the 1048 Phidget which reads thermistors, you would need a Phidgets board with analog inputs like the 1010,1011, 1018, 1019 or the SBC.
You could then use the plugin to create a generic sensor and a custom formula to produce the appropriate output value for your sensors.
Fri Jun 21, 2013 12:37 pm
midd offline
Anyone else using Vegetronix soil moisture sensors? I'd like to see/use your formula.
Wed Jun 26, 2013 5:37 pm
loafbread offline
Berkinet, has there been a Phidgets update since 0.5.3? Are you still traveling? I am holding off on the recent Indigo updates until Phidgets is compatible. I am totally dependent on Phidgets now :)
Thu Jun 27, 2013 1:21 am
berkinet offline
I will be putting up 0.56 in the next day or so. This will address problems related to changes in the plugin interface introduced in I6b9. But, other than adding the 3130 humidity sensor there are no significant changes.
Sat Jul 06, 2013 7:06 am
midd offline
I was able to get my Phidgets board and vegetronix moisture sensor setup through Indigo. Thanks berkinet for the plugin and gtreece for your help. However I'm not getting any updated readings. The last reading was the initial reading when I first connected everything together. To get a new reading I have to unplug the USB cable from my mac mini and plug it back in.
Sat Jul 06, 2013 11:01 am
berkinet offline
midd wrote:
...I'm not getting any updated readings. The last reading was the initial reading when I first connected everything together. To get a new reading I have to unplug the USB cable from my mac mini and plug it back in.
That's not much information to go on. But, If I had to guess, I'd say you have configured the Phidgets plugin to connect to your InterfaceKit using USB and you also have the Phidgets preference panel open at the same time. Or you have the InterfaceKit open in the preference panel using ISB. When using USB only one program at a time may access the USB port. If this is the case, the solution is to turn on the Phidgets Web Service (in the Phidgets Control Panel) and then configure the plugin to connect to the InterfaceKit over IP at 127.0.0.1 at whatever port you set when you started the web service (default is 5001).
If this is not the case. Then please provide the details of your setup. Also, you might try testing with the Phidgets Preference panel using the listing for your InterfaceKit found on the Bonjour tab of the preference pane. That way it will also use the web service and not conflict with the plugin.
Sat Jul 06, 2013 11:24 am
midd offline
Thanks for the response. The control panel was closed. I had the Phidgets connection set to USB. Once I changed it to IP network, it updated. Will keep an eye to make sure it continues to update.
Sun Jul 07, 2013 2:31 pm
midd offline
Well I'm still not getting any updates to readouts from my Vegetronix moisture sensor and my Phidgets 1018 Interface Kit. I watered outback and decided to soak the area where my vegetronix is. There was no change to the variable or voltage. The sensor is connected to input 0. If I unplug and replug the USB cable, I'll get an initial reading
Here is a pic of the Phidgets Interface setup in Indigo:
Here is a pic of the Vegetronix setup in Indigo:
and here is a pic of the Phidgets Control Panel (which has been closed) from the System Preferences:
Any help is appreciated!
Page 10 of 39 1 ... 7, 8, 9, 10, 11, 12, 13 ... 39
