ad2usb plugin discussion
Sun Oct 06, 2019 9:06 pm
hamw offline
Re: ad2usb plugin discussion
I did, thanks. I made my own buttons on a control page, and execute the built-in executables from there. That all works fine from my control; my issue is having lost the ser2sock interface for some reason. Anyway it works fine over USB, so no issue at this point.
Tue Nov 19, 2019 8:21 pm
mattyf offline
Sometimes my pi stops working and then Indigo just doesn't do the things I'm expecting it to do. Is there some way to check for connection errors between the indigo plugin and the pi, so I can get a notification of issues proactively?
Wed Nov 20, 2019 11:02 am
berkinet offline
You might...
  • Make sure the Pi is completely up-to-date on all the Linux libs
  • Setup a background task in Indigo to regularly ping the Pi -- if it is really non-responsive
  • If you have regular updates from your alarm system, setup a trigger for any change in the keypad and use the to update a time stamp in a variable. Then use another trigger to see if the variable gets too old
  • Replace the Pi
Sat Nov 30, 2019 1:07 pm
wideglidejrp offline
I am getting a new error I have not seen before. Any suggestions?
AD2USB Alarm Interface Error Error on line 733
AD2USB Alarm Interface Error panelMsgRead: Error: invalid literal for int() with base 10: '0fc'
John R Patrick
Author of
Home Attitude
Mon Dec 16, 2019 3:01 am
berkinet offline
Sorry for the delay, I was traveling for the past few weeks. It looks like a zoner name is being misinterpreted, but I really have no idea what is causing the issue you are experiencing. I'd just suggest that if you have changed anything at all in the past few weeks, that might be the cause.
Mon Jan 27, 2020 6:18 pm
roquej offline
Search, but couldn't find the issue.
I am getting: "AD2USB Alarm Interface Error advancedReadZoneMessage: Unable to update state table for zone 04, address 18."
It happens with different zones.
Any ideas?
JP
Tue May 26, 2020 9:12 pm
JonathanKing offline
Current status?
Hi all,
I am considering getting an AD2Pi and wonder if anyone can say whether the product is stable and solid? It's currently out of stock
http://www.alarmdecoder.com/catalog/pro ... ucts_id/39
but it seems to be the only way to get data from my honeywell vista alarm system into Indigo.
Is the plugin under active development (not a criticism, just want to know if the $200 hardware investment will work long-term)
Wed May 27, 2020 10:12 am
berkinet offline
Re: Current status?
JonathanKing wrote:
...Is the plugin under active development (not a criticism, just want to know if the $200 hardware investment will work long-term)
Define active? It is a mature plugin in a mature niche. As long as the Honeywell protocol doesn't change, I can't really see much need for further development. But, should there be a need at some point, there would still be developed as required.
As far as the AD2* goes. If your budget can handle it, I highly recommend the AD2PI. You can stick it in the alarm cabined and be done. No USB cables to run.
Sat Sep 12, 2020 6:49 pm
hamw offline
Got a new 20p for another house. Installed Indigo and now AD2USB. It is communicating fine via Ser2Sock and telnets fine but won't set the alarm. Just "sending...." etc. Any thoughts? Here is a debug.
gin "AD2USB Alarm Interface 1.6.0"
   Stopping plugin "AD2USB Alarm Interface 1.6.0" (pid 4938)
   AD2USB Alarm Interface          stopConcurrentThread Called
   AD2USB Alarm Interface          stopComm Called
   AD2USB Alarm Interface          stopComm Started
   AD2USB Alarm Interface          panelMsgRead: Connection Closed:
   AD2USB Alarm Interface          runConcurrentThread Process completed, Restarting
   AD2USB Alarm Interface          stopConcurrentThread completed
   AD2USB Alarm Interface          deviceStopComm Called
   AD2USB Alarm Interface          deviceStopComm: devName:01 Smoke Detector, devId:726060232, devTypeId:alarmZone
   AD2USB Alarm Interface          deviceStopComm completed
   AD2USB Alarm Interface          deviceStopComm: devName:02 Front Door, devId:1483459099, devTypeId:alarmZone
   AD2USB Alarm Interface          deviceStopComm: devName:03 MBR Door, devId:1765317357, devTypeId:alarmZone
   AD2USB Alarm Interface          deviceStopComm: devName:04 Living Room Door, devId:190834306, devTypeId:alarmZone
   AD2USB Alarm Interface          deviceStopComm: devName:05 Basement Door, devId:910060734, devTypeId:alarmZone
   AD2USB Alarm Interface          deviceStopComm: devName:06 Upstairs Motion, devId:1934785811, devTypeId:alarmZone
   AD2USB Alarm Interface          deviceStopComm: devName:07 Downstairs Motion, devId:33894021, devTypeId:alarmZone
   AD2USB Alarm Interface          deviceStopComm: devName:08 Phone Tamper, devId:1511284117, devTypeId:alarmZone
   AD2USB Alarm Interface          deviceStopComm: devName:09 Porch Sliding Door, devId:24090632, devTypeId:alarmZone
   AD2USB Alarm Interface          deviceStopComm: devName:11 PIR 45, devId:601314109, devTypeId:alarmZone
   AD2USB Alarm Interface          deviceStopComm: devName:Alarm AD2USB Keypad, devId:880348765, devTypeId:ad2usbInterface
   Stopped plugin "AD2USB Alarm Interface 1.6.0"
   Starting plugin "AD2USB Alarm Interface 1.6.0" (pid 4939)
   AD2USB Alarm Interface          Log level preferences are set to "Debug".
   AD2USB Alarm Interface          __init__ Called
   AD2USB Alarm Interface          __init__ Completed
   Started plugin "AD2USB Alarm Interface 1.6.0"
   AD2USB Alarm Interface          startup Called
   AD2USB Alarm Interface          Plugin setup completed. Ready to open link to the ad2usb in Advanced mode.
   AD2USB Alarm Interface          startup completed
   AD2USB Alarm Interface          deviceStartComm Called
   AD2USB Alarm Interface          deviceStartComm: devName:01 Smoke Detector, devId:726060232, devTypeId:alarmZone, clearAllOnRestart:True
   AD2USB Alarm Interface          basicBuildDevDict Called for function:add
   AD2USB Alarm Interface          basicBuildDevDict: Added record for Device:01 Smoke Detector, Zone:1
   AD2USB Alarm Interface          basicBuildDevDict: Wrote record:{'state': '', 'devId': 726060232, 'number': 1, 'name': u'01 Smoke Detector', 'logChanges': False}
   AD2USB Alarm Interface          basicBuildDevDict completed
   AD2USB Alarm Interface          advancedBuildDevDict Called for devce:01 Smoke Detector,  Type:alarmZone, function:add
   AD2USB Alarm Interface          advancedBuildDevDict: Added record for Device:01 Smoke Detector, Zone:01
   AD2USB Alarm Interface          advancedBuildDevDict: Wrote record:{'logSupervision': True, 'state': '', 'partition': u'1', 'board': u'12', 'name': u'01 Smoke Detector', 'device': u'01', 'devId': 726060232, 'type': u'REL', 'number': u'01', 'logChanges': False}
   AD2USB Alarm Interface          advancedBuildDevDict completed
   AD2USB Alarm Interface          deviceStartComm completed
   AD2USB Alarm Interface          deviceStartComm: devName:02 Front Door, devId:1483459099, devTypeId:alarmZone, clearAllOnRestart:True
   AD2USB Alarm Interface          basicBuildDevDict: Added record for Device:02 Front Door, Zone:2
   AD2USB Alarm Interface          basicBuildDevDict: Wrote record:{'state': '', 'devId': 1483459099, 'number': 2, 'name': u'02 Front Door', 'logChanges': False}
   AD2USB Alarm Interface          advancedBuildDevDict Called for devce:02 Front Door,  Type:alarmZone, function:add
   AD2USB Alarm Interface          advancedBuildDevDict: Added record for Device:02 Front Door, Zone:02
   AD2USB Alarm Interface          advancedBuildDevDict: Wrote record:{'logSupervision': True, 'state': '', 'partition': u'1', 'board': u'12', 'name': u'02 Front Door', 'device': u'02', 'devId': 1483459099, 'type': u'REL', 'number': u'02', 'logChanges': False}
   AD2USB Alarm Interface          deviceStartComm: devName:03 MBR Door, devId:1765317357, devTypeId:alarmZone, clearAllOnRestart:True
   AD2USB Alarm Interface          basicBuildDevDict: Added record for Device:03 MBR Door, Zone:3
   AD2USB Alarm Interface          basicBuildDevDict: Wrote record:{'state': '', 'devId': 1765317357, 'number': 3, 'name': u'03 MBR Door', 'logChanges': False}
   AD2USB Alarm Interface          advancedBuildDevDict Called for devce:03 MBR Door,  Type:alarmZone, function:add
   AD2USB Alarm Interface          advancedBuildDevDict: Added record for Device:03 MBR Door, Zone:03
   AD2USB Alarm Interface          advancedBuildDevDict: Wrote record:{'logSupervision': True, 'state': '', 'partition': u'1', 'board': u'12', 'name': u'03 MBR Door', 'device': u'03', 'devId': 1765317357, 'type': u'REL', 'number': u'03', 'logChanges': False}
   AD2USB Alarm Interface          deviceStartComm: devName:04 Living Room Door, devId:190834306, devTypeId:alarmZone, clearAllOnRestart:True
   AD2USB Alarm Interface          basicBuildDevDict: Added record for Device:04 Living Room Door, Zone:4
   AD2USB Alarm Interface          basicBuildDevDict: Wrote record:{'state': '', 'devId': 190834306, 'number': 4, 'name': u'04 Living Room Door', 'logChanges': False}
   AD2USB Alarm Interface          advancedBuildDevDict Called for devce:04 Living Room Door,  Type:alarmZone, function:add
   AD2USB Alarm Interface          advancedBuildDevDict: Added record for Device:04 Living Room Door, Zone:04
   AD2USB Alarm Interface          advancedBuildDevDict: Wrote record:{'logSupervision': True, 'state': '', 'partition': u'1', 'board': u'12', 'name': u'04 Living Room Door', 'device': u'04', 'devId': 190834306, 'type': u'REL', 'number': u'04', 'logChanges': False}
   AD2USB Alarm Interface          deviceStartComm: devName:05 Basement Door, devId:910060734, devTypeId:alarmZone, clearAllOnRestart:True
   AD2USB Alarm Interface          basicBuildDevDict: Added record for Device:05 Basement Door, Zone:5
   AD2USB Alarm Interface          basicBuildDevDict: Wrote record:{'state': '', 'devId': 910060734, 'number': 5, 'name': u'05 Basement Door', 'logChanges': False}
   AD2USB Alarm Interface          advancedBuildDevDict Called for devce:05 Basement Door,  Type:alarmZone, function:add
   AD2USB Alarm Interface          advancedBuildDevDict: Added record for Device:05 Basement Door, Zone:05
   AD2USB Alarm Interface          advancedBuildDevDict: Wrote record:{'logSupervision': True, 'state': '', 'partition': u'1', 'board': u'13', 'name': u'05 Basement Door', 'device': u'01', 'devId': 910060734, 'type': u'REL', 'number': u'05', 'logChanges': False}
   AD2USB Alarm Interface          deviceStartComm: devName:06 Upstairs Motion, devId:1934785811, devTypeId:alarmZone, clearAllOnRestart:True
   AD2USB Alarm Interface          basicBuildDevDict: Added record for Device:06 Upstairs Motion, Zone:6
   AD2USB Alarm Interface          basicBuildDevDict: Wrote record:{'state': '', 'devId': 1934785811, 'number': 6, 'name': u'06 Upstairs Motion', 'logChanges': False}
   AD2USB Alarm Interface          advancedBuildDevDict Called for devce:06 Upstairs Motion,  Type:alarmZone, function:add
   AD2USB Alarm Interface          advancedBuildDevDict: Added record for Device:06 Upstairs Motion, Zone:06
   AD2USB Alarm Interface          advancedBuildDevDict: Wrote record:{'logSupervision': True, 'state': '', 'partition': u'1', 'board': u'13', 'name': u'06 Upstairs Motion', 'device': u'02', 'devId': 1934785811, 'type': u'REL', 'number': u'06', 'logChanges': False}
   AD2USB Alarm Interface          deviceStartComm: devName:07 Downstairs Motion, devId:33894021, devTypeId:alarmZone, clearAllOnRestart:True
   AD2USB Alarm Interface          basicBuildDevDict: Added record for Device:07 Downstairs Motion, Zone:7
   AD2USB Alarm Interface          basicBuildDevDict: Wrote record:{'state': '', 'devId': 33894021, 'number': 7, 'name': u'07 Downstairs Motion', 'logChanges': False}
   AD2USB Alarm Interface          advancedBuildDevDict Called for devce:07 Downstairs Motion,  Type:alarmZone, function:add
   AD2USB Alarm Interface          advancedBuildDevDict: Added record for Device:07 Downstairs Motion, Zone:07
   AD2USB Alarm Interface          advancedBuildDevDict: Wrote record:{'logSupervision': True, 'state': '', 'partition': u'1', 'board': u'13', 'name': u'07 Downstairs Motion', 'device': u'03', 'devId': 33894021, 'type': u'REL', 'number': u'07', 'logChanges': False}
   AD2USB Alarm Interface          deviceStartComm: devName:08 Phone Tamper, devId:1511284117, devTypeId:alarmZone, clearAllOnRestart:True
   AD2USB Alarm Interface          basicBuildDevDict: Added record for Device:08 Phone Tamper, Zone:8
   AD2USB Alarm Interface          basicBuildDevDict: Wrote record:{'state': '', 'devId': 1511284117, 'number': 8, 'name': u'08 Phone Tamper', 'logChanges': False}
   AD2USB Alarm Interface          advancedBuildDevDict Called for devce:08 Phone Tamper,  Type:alarmZone, function:add
   AD2USB Alarm Interface          advancedBuildDevDict: Added record for Device:08 Phone Tamper, Zone:08
   AD2USB Alarm Interface          advancedBuildDevDict: Wrote record:{'logSupervision': True, 'state': '', 'partition': u'1', 'board': u'13', 'name': u'08 Phone Tamper', 'device': u'04', 'devId': 1511284117, 'type': u'REL', 'number': u'08', 'logChanges': False}
   AD2USB Alarm Interface          deviceStartComm: devName:09 Porch Sliding Door, devId:24090632, devTypeId:alarmZone, clearAllOnRestart:True
   AD2USB Alarm Interface          basicBuildDevDict: Added record for Device:09 Porch Sliding Door, Zone:9
   AD2USB Alarm Interface          basicBuildDevDict: Wrote record:{'state': '', 'devId': 24090632, 'number': 9, 'name': u'09 Porch Sliding Door', 'logChanges': True}
   AD2USB Alarm Interface          advancedBuildDevDict Called for devce:09 Porch Sliding Door,  Type:alarmZone, function:add
   AD2USB Alarm Interface          advancedBuildDevDict: Added record for Device:09 Porch Sliding Door, Zone:09
   AD2USB Alarm Interface          advancedBuildDevDict: Wrote record:{'logSupervision': True, 'state': '', 'partition': u'1', 'board': u'', 'name': u'09 Porch Sliding Door', 'device': u'01', 'devId': 24090632, 'type': u'RFX', 'number': u'09', 'logChanges': True}
   AD2USB Alarm Interface          deviceStartComm: devName:11 PIR 45, devId:601314109, devTypeId:alarmZone, clearAllOnRestart:True
   AD2USB Alarm Interface          basicBuildDevDict: Added record for Device:11 PIR 45, Zone:11
   AD2USB Alarm Interface          basicBuildDevDict: Wrote record:{'state': '', 'devId': 601314109, 'number': 11, 'name': u'11 PIR 45', 'logChanges': True}
   AD2USB Alarm Interface          advancedBuildDevDict Called for devce:11 PIR 45,  Type:alarmZone, function:add
   AD2USB Alarm Interface          advancedBuildDevDict: Added record for Device:11 PIR 45, Zone:11
   AD2USB Alarm Interface          advancedBuildDevDict: Wrote record:{'logSupervision': True, 'state': '', 'partition': u'1', 'board': u'0384004', 'name': u'11 PIR 45', 'device': u'01', 'devId': 601314109, 'type': u'RFX', 'number': u'11', 'logChanges': True}
   AD2USB Alarm Interface          deviceStartComm: devName:Alarm AD2USB Keypad, devId:880348765, devTypeId:ad2usbInterface, clearAllOnRestart:True
   AD2USB Alarm Interface          addPanelDev Called
   AD2USB Alarm Interface          addPanelDev: Added address to partition record:{'devId': 880348765, 'name': u'Alarm AD2USB Keypad', 'partition': u'1'}
   AD2USB Alarm Interface          addPanelDev completed
   AD2USB Alarm Interface          advancedBuildDevDict Called for devce:Alarm AD2USB Keypad,  Type:ad2usbInterface, function:add
   AD2USB Alarm Interface          addPanelDev: Added partition to address record:{'devId': 880348765, 'name': u'Alarm AD2USB Keypad', 'address': u'31'}
   AD2USB Alarm Interface          runConcurrentThread Called
   AD2USB Alarm Interface          startComm Called
   AD2USB Alarm Interface          startComm: isAdvanced:True, commType:IP, address:127.0.0.1, port:15005, serialPort:/dev/cu.usbserial-A1018WW3
   AD2USB Alarm Interface          startComm: Read alarm status dict:{'010': 'armedAway', '001': 'armedStay', '000': 'Fault', '100': 'ready'}
   AD2USB Alarm Interface          startComm: Loading zonesDict
   AD2USB Alarm Interface          ad2usb opened for communication at socket://127.0.0.1:15005
   AD2USB Alarm Interface          panelMsgRead Called
   AD2USB Alarm Interface          panelMsgRead: isAdvanced:True
   AD2USB Alarm Interface          panelMsgRead: SER2SOCK connection or null Message: we passed on this one
   AD2USB Alarm Interface          panelMsgRead: panelMsgRead End
SENDING PANEL QUICK WRITE
   AD2USB Alarm Interface          panelQuckArmWrite Called
   AD2USB Alarm Interface          panelQuckArmWrite: Received:configured : True
delayAmount : 900
description : arm-stay
deviceId : 0
pluginId : com.berkinet.ad2usb
pluginTypeId : writeArmStayPanel
props : com.berkinet.ad2usb : (dict)
     armingCode : #3 (string)
     keypadAddress : 31 (string)
replaceExisting : True
textToSpeak :
   AD2USB Alarm Interface          panelQuckArmWrite: Created message:#3
   AD2USB Alarm Interface          panelMsgWrite Called
   AD2USB Alarm Interface          panelMsgWrite: Received msg:#3 for address:31
   AD2USB Alarm Interface          panelMsgWrite Completed
   AD2USB Alarm Interface          panelQuckArmWrite completed
   AD2USB Alarm Interface          panelMsgWrite: Received:configured : True
delayAmount : 900
description : write to panel
deviceId : 0
pluginTypeId : writeToPanel
****SENDING INDIVIDUAL CODE NUMBERS AS STRING TO THE PANEL TO SE T THE ALARM *****
     panelMessage : (string)
textToSpeak :
   AD2USB Alarm Interface          panelMsgWrite: Created message:XXXXX <<<<<<<<  THE CODE
   AD2USB Alarm Interface          panelMsgWrite: Received msg:XXXXX for address:31
   AD2USB Alarm Interface          panelMsgWrite completed
   AD2USB Alarm Interface          panelMsgRead: Calling advanced for:Sen
   AD2USB Alarm Interface          advancedReadZoneMessage Called
   AD2USB Alarm Interface          advancedReadZoneMessage: Received:!Sending......done
   AD2USB Alarm Interface          advancedReadZoneMessage Completed
   AD2USB Alarm Interface          panelMsgRead: raw zone type is:[100
   AD2USB Alarm Interface          panelMsgRead: Panel Message: Before:=[1000000100000000----],008,[f70000ff1008001c08020000000000],"****DISARMED****  Ready to Arm  "
, Current=
   AD2USB Alarm Interface          panelMsgRead: Panel message:[1000000100000000----],
   AD2USB Alarm Interface          panelMsgRead: Found dev: Alarm AD2USB Keypad, id:880348765
   AD2USB Alarm Interface          panelMsgRead: current:0, last 0
Alarm is not setting. Any thoughts?
Sun Sep 27, 2020 11:18 am
hamw offline
Bump. Hoping to get this to work. I was running it on Indigo 7.1 and updated to 7.4.1 with no luck.
FWIW it is a new 20p panel, "WA20P" Rev 10.23
Wed Sep 30, 2020 10:24 am
berkinet offline
I have looked at your post and can see nothing that would cause the problem you are experiencing. All I can think is that you are possibly running a new firmware on the ad2*.
Wed Sep 30, 2020 11:05 am
hamw offline
That’s a good suggestion. Do you know the last compatible firmware version?
berkinet offline
Not off hand. But, it would be a few years ago.
Wed Sep 30, 2020 12:28 pm
gt3mike offline
I am running 2.2a.6 . I found it via trial and error. Anything newer wouldn't work for me.
Sun Oct 04, 2020 8:01 am
hamw offline
I got MonoGUI working with the intent of loading 2a.6... I had been down this road before and already had done that.
[quote]10/4/2020 9:55:14 AM !
10/4/2020 9:55:15 AM !Ademco Keypad Emulator V2.2a.6
10/4/2020 9:55:15 AM !Copyright (C) 2008-2010 Nu Tech Software Solutions, Inc.
10/4/2020 9:55:15 AM !Reproduction without permission is prohibited
10/4/2020 9:55:15 AM !By Sean Mathews <drwho at f34r.com>
10/4/2020 9:55:15 AM !For support email general@support.nutech.com
10/4/2020 9:55:15 AM !www.NuTech.com
10/4/2020 9:55:15 AM !Reading configuration.
10/4/2020 9:55:15 AM !UART init.
10/4/2020 9:55:23 AM !Ready. Press ! for configuration./quote]
Is it possible this device has gone bad? It appears to be hooked up correctly as it receives. Not sure if the panel is not responding or if the AD2USB is not sending correctly.
