ad2usb plugin discussion
Sat May 12, 2018 7:04 am
maslett offline
Re: ad2usb plugin discussion
Berkinet, apologies for the confusing response. I have made some progress. I got the installer code and added the keypad. The messages are now showing up in NC but the plugin is not showing the messages rather just error codes as shown below. Thanks for the assistance, Mark
Screen Shot 2018-05-12 at 9.11.06 AM.png (494.88 KiB) Viewed 1784 times
Screen Shot 2018-05-12 at 8.50.59 AM 2.png (479.83 KiB) Viewed 1786 times
Sat May 12, 2018 7:50 am
berkinet offline
maslett wrote:
Berkinet, apologies for the confusing response. I have made some progress. I got the installer code and added the keypad. The messages are now showing up in NC but the plugin is not showing the messages rather just error codes as shown below. ... Mark
Delete your keypad device, then recreate it and then restart the plugin. If that does not resolve the problem, you may also need to delete and recreate the zone devices.
Sat May 12, 2018 8:00 am
berkinet offline
wikner wrote:
...and a whole bunch of these:
   AD2USB Alarm Interface Error    Error on line 795
   AD2USB Alarm Interface Error    panelMsgRead: Error: log() takes exactly 5 arguments (4 given)
using 1.6.1
Sorry. Trying to code without being able to test can cause problems... try this:
https://drive.google.com/open?id=15K48L ... fo99bb9Mw6
Sat May 12, 2018 9:15 am
maslett offline
Berkinet, thanks. I deleted the keypad and all zones. I created a new keypad which now shows clear and faulted. However it appears the plugin works for a little while and then crashes as it reads messages as various newly created zones are triggered. See attached. Thanks, Mark
Screen Shot 2018-05-12 at 11.26.13 AM.png (495.88 KiB) Viewed 1769 times
Screen Shot 2018-05-12 at 11.12.58 AM.png (496.14 KiB) Viewed 1771 times
Screen Shot 2018-05-12 at 11.02.00 AM.png (487.53 KiB) Viewed 1771 times
Sat May 12, 2018 9:55 am
berkinet offline
Did you restart the plugin after creating the new zones?
You can also try the version I posted earlier today to this threads. It will not fix the problem. But, may give better error messages.
Sat May 12, 2018 1:42 pm
maslett offline
Berkinet, I installed the new version and things appear to be working. thank you for all your help. Mark
Sat May 12, 2018 2:10 pm
berkinet offline
Thanks for letting me know. Did you get any series of log messages starting with " Zone Event test:...? If so, could you post a few here
Sat May 12, 2018 3:46 pm
maslett offline
Once I stopped getting the error messages I downgraded to 1,6 and the error messages stopped. A little weird. Maybe there was something weird on my end with the install once the keypad programming issue was resolved. I will reinstall 1.6.2 and post a few logs. Although I don't think I have any error messages right now. Thanks once again.
Sat May 12, 2018 3:54 pm
maslett offline
I reinstalled 1.6.2 seems to be working fine. There are no further extended error messages. Screen shot attached. I'll leave as is and will post any logs with extended error reporting if the occur. Thanks, Mark
Screen Shot 2018-05-12 at 5.49.22 PM.png (498.22 KiB) Viewed 1685 times
Sun May 20, 2018 6:01 pm
maslett offline
Faulted zone's not clearing
Berkinet,
I noticed an anomaly with 1.6.2.
If I have a zone that is purposely faulted, for example I leave the kitchen window open for ventilation, then when a motion detector triggers it does not clear. If there isn't a faulted zone, ie the kitchen window is closed, then the motion detectors fault then clear normally.
Unfortunately there are no errors messages.
Thanks, Mark
Wed May 23, 2018 11:46 am
berkinet offline
Re: Faulted zone's not clearing
maslett wrote:
...I noticed an anomaly with 1.6.2.
V 1.6.2 was for trying to debug the problems reported by @wikner (who seems to have disappeared). It was not intended for general use. Try going back to v1.6.1.
Wed May 23, 2018 12:41 pm
maslett offline
Ok I will try doing when I return. Thanks.
Wed May 23, 2018 3:28 pm
wikner offline
V 1.6.2
I haven't disappeared, just busy. I am running 1.6.2. Do you want me to send you another high-debug-level log?
Thu May 24, 2018 1:35 am
berkinet offline
Re: V 1.6.2
wikner wrote:
...I am running 1.6.2. Do you want me to send you another high-debug-level log?
Are there any log messages containing "Zone Event test "? If so, please copy a few and post them here.
Thu May 24, 2018 10:35 am
wikner offline
berkinet wrote:
Re: V 1.6.2
There were 5957 such messages yesterday. Here are a few.
Zone Events Test.txt
(13.38 KiB) Downloaded 33 times
Page 53 of 58 1 ... 50, 51, 52, 53, 54, 55, 56 ... 58
