mattyf wrote:Sometimes my pi stops working and then Indigo just doesn't do the things I'm expecting it to do. Is there some way to check for connection errors between the indigo plugin and the pi, so I can get a notification of issues proactively?
wideglidejrp wrote:Sorry for the delay, I was traveling for the past few weeks. It looks like a zoner name is being misinterpreted, but I really have no idea what is causing the issue you are experiencing. I'd just suggest that if you have changed anything at all in the past few weeks, that might be the cause.I am getting a new error I have not seen before. Any suggestions?
AD2USB Alarm Interface Error Error on line 733
AD2USB Alarm Interface Error panelMsgRead: Error: invalid literal for int() with base 10: '0fc'
JonathanKing wrote:Define active? It is a mature plugin in a mature niche. As long as the Honeywell protocol doesn't change, I can't really see much need for further development. But, should there be a need at some point, there would still be developed as required....Is the plugin under active development (not a criticism, just want to know if the $200 hardware investment will work long-term)
gin "AD2USB Alarm Interface 1.6.0"
Stopping plugin "AD2USB Alarm Interface 1.6.0" (pid 4938)
AD2USB Alarm Interface stopConcurrentThread Called
AD2USB Alarm Interface stopComm Called
AD2USB Alarm Interface stopComm Started
AD2USB Alarm Interface panelMsgRead: Connection Closed:
AD2USB Alarm Interface runConcurrentThread Process completed, Restarting
AD2USB Alarm Interface stopConcurrentThread completed
AD2USB Alarm Interface deviceStopComm Called
AD2USB Alarm Interface deviceStopComm: devName:01 Smoke Detector, devId:726060232, devTypeId:alarmZone
AD2USB Alarm Interface deviceStopComm completed
AD2USB Alarm Interface deviceStopComm: devName:02 Front Door, devId:1483459099, devTypeId:alarmZone
AD2USB Alarm Interface deviceStopComm: devName:03 MBR Door, devId:1765317357, devTypeId:alarmZone
AD2USB Alarm Interface deviceStopComm: devName:04 Living Room Door, devId:190834306, devTypeId:alarmZone
AD2USB Alarm Interface deviceStopComm: devName:05 Basement Door, devId:910060734, devTypeId:alarmZone
AD2USB Alarm Interface deviceStopComm: devName:06 Upstairs Motion, devId:1934785811, devTypeId:alarmZone
AD2USB Alarm Interface deviceStopComm: devName:07 Downstairs Motion, devId:33894021, devTypeId:alarmZone
AD2USB Alarm Interface deviceStopComm: devName:08 Phone Tamper, devId:1511284117, devTypeId:alarmZone
AD2USB Alarm Interface deviceStopComm: devName:09 Porch Sliding Door, devId:24090632, devTypeId:alarmZone
AD2USB Alarm Interface deviceStopComm: devName:11 PIR 45, devId:601314109, devTypeId:alarmZone
AD2USB Alarm Interface deviceStopComm: devName:Alarm AD2USB Keypad, devId:880348765, devTypeId:ad2usbInterface
Stopped plugin "AD2USB Alarm Interface 1.6.0"
Starting plugin "AD2USB Alarm Interface 1.6.0" (pid 4939)
AD2USB Alarm Interface Log level preferences are set to "Debug".
AD2USB Alarm Interface __init__ Called
AD2USB Alarm Interface __init__ Completed
Started plugin "AD2USB Alarm Interface 1.6.0"
AD2USB Alarm Interface startup Called
AD2USB Alarm Interface Plugin setup completed. Ready to open link to the ad2usb in Advanced mode.
AD2USB Alarm Interface startup completed
AD2USB Alarm Interface deviceStartComm Called
AD2USB Alarm Interface deviceStartComm: devName:01 Smoke Detector, devId:726060232, devTypeId:alarmZone, clearAllOnRestart:True
AD2USB Alarm Interface basicBuildDevDict Called for function:add
AD2USB Alarm Interface basicBuildDevDict: Added record for Device:01 Smoke Detector, Zone:1
AD2USB Alarm Interface basicBuildDevDict: Wrote record:{'state': '', 'devId': 726060232, 'number': 1, 'name': u'01 Smoke Detector', 'logChanges': False}
AD2USB Alarm Interface basicBuildDevDict completed
AD2USB Alarm Interface advancedBuildDevDict Called for devce:01 Smoke Detector, Type:alarmZone, function:add
AD2USB Alarm Interface advancedBuildDevDict: Added record for Device:01 Smoke Detector, Zone:01
AD2USB Alarm Interface advancedBuildDevDict: Wrote record:{'logSupervision': True, 'state': '', 'partition': u'1', 'board': u'12', 'name': u'01 Smoke Detector', 'device': u'01', 'devId': 726060232, 'type': u'REL', 'number': u'01', 'logChanges': False}
AD2USB Alarm Interface advancedBuildDevDict completed
AD2USB Alarm Interface deviceStartComm completed
AD2USB Alarm Interface deviceStartComm: devName:02 Front Door, devId:1483459099, devTypeId:alarmZone, clearAllOnRestart:True
AD2USB Alarm Interface basicBuildDevDict: Added record for Device:02 Front Door, Zone:2
AD2USB Alarm Interface basicBuildDevDict: Wrote record:{'state': '', 'devId': 1483459099, 'number': 2, 'name': u'02 Front Door', 'logChanges': False}
AD2USB Alarm Interface advancedBuildDevDict Called for devce:02 Front Door, Type:alarmZone, function:add
AD2USB Alarm Interface advancedBuildDevDict: Added record for Device:02 Front Door, Zone:02
AD2USB Alarm Interface advancedBuildDevDict: Wrote record:{'logSupervision': True, 'state': '', 'partition': u'1', 'board': u'12', 'name': u'02 Front Door', 'device': u'02', 'devId': 1483459099, 'type': u'REL', 'number': u'02', 'logChanges': False}
AD2USB Alarm Interface deviceStartComm: devName:03 MBR Door, devId:1765317357, devTypeId:alarmZone, clearAllOnRestart:True
AD2USB Alarm Interface basicBuildDevDict: Added record for Device:03 MBR Door, Zone:3
AD2USB Alarm Interface basicBuildDevDict: Wrote record:{'state': '', 'devId': 1765317357, 'number': 3, 'name': u'03 MBR Door', 'logChanges': False}
AD2USB Alarm Interface advancedBuildDevDict Called for devce:03 MBR Door, Type:alarmZone, function:add
AD2USB Alarm Interface advancedBuildDevDict: Added record for Device:03 MBR Door, Zone:03
AD2USB Alarm Interface advancedBuildDevDict: Wrote record:{'logSupervision': True, 'state': '', 'partition': u'1', 'board': u'12', 'name': u'03 MBR Door', 'device': u'03', 'devId': 1765317357, 'type': u'REL', 'number': u'03', 'logChanges': False}
AD2USB Alarm Interface deviceStartComm: devName:04 Living Room Door, devId:190834306, devTypeId:alarmZone, clearAllOnRestart:True
AD2USB Alarm Interface basicBuildDevDict: Added record for Device:04 Living Room Door, Zone:4
AD2USB Alarm Interface basicBuildDevDict: Wrote record:{'state': '', 'devId': 190834306, 'number': 4, 'name': u'04 Living Room Door', 'logChanges': False}
AD2USB Alarm Interface advancedBuildDevDict Called for devce:04 Living Room Door, Type:alarmZone, function:add
AD2USB Alarm Interface advancedBuildDevDict: Added record for Device:04 Living Room Door, Zone:04
AD2USB Alarm Interface advancedBuildDevDict: Wrote record:{'logSupervision': True, 'state': '', 'partition': u'1', 'board': u'12', 'name': u'04 Living Room Door', 'device': u'04', 'devId': 190834306, 'type': u'REL', 'number': u'04', 'logChanges': False}
AD2USB Alarm Interface deviceStartComm: devName:05 Basement Door, devId:910060734, devTypeId:alarmZone, clearAllOnRestart:True
AD2USB Alarm Interface basicBuildDevDict: Added record for Device:05 Basement Door, Zone:5
AD2USB Alarm Interface basicBuildDevDict: Wrote record:{'state': '', 'devId': 910060734, 'number': 5, 'name': u'05 Basement Door', 'logChanges': False}
AD2USB Alarm Interface advancedBuildDevDict Called for devce:05 Basement Door, Type:alarmZone, function:add
AD2USB Alarm Interface advancedBuildDevDict: Added record for Device:05 Basement Door, Zone:05
AD2USB Alarm Interface advancedBuildDevDict: Wrote record:{'logSupervision': True, 'state': '', 'partition': u'1', 'board': u'13', 'name': u'05 Basement Door', 'device': u'01', 'devId': 910060734, 'type': u'REL', 'number': u'05', 'logChanges': False}
AD2USB Alarm Interface deviceStartComm: devName:06 Upstairs Motion, devId:1934785811, devTypeId:alarmZone, clearAllOnRestart:True
AD2USB Alarm Interface basicBuildDevDict: Added record for Device:06 Upstairs Motion, Zone:6
AD2USB Alarm Interface basicBuildDevDict: Wrote record:{'state': '', 'devId': 1934785811, 'number': 6, 'name': u'06 Upstairs Motion', 'logChanges': False}
AD2USB Alarm Interface advancedBuildDevDict Called for devce:06 Upstairs Motion, Type:alarmZone, function:add
AD2USB Alarm Interface advancedBuildDevDict: Added record for Device:06 Upstairs Motion, Zone:06
AD2USB Alarm Interface advancedBuildDevDict: Wrote record:{'logSupervision': True, 'state': '', 'partition': u'1', 'board': u'13', 'name': u'06 Upstairs Motion', 'device': u'02', 'devId': 1934785811, 'type': u'REL', 'number': u'06', 'logChanges': False}
AD2USB Alarm Interface deviceStartComm: devName:07 Downstairs Motion, devId:33894021, devTypeId:alarmZone, clearAllOnRestart:True
AD2USB Alarm Interface basicBuildDevDict: Added record for Device:07 Downstairs Motion, Zone:7
AD2USB Alarm Interface basicBuildDevDict: Wrote record:{'state': '', 'devId': 33894021, 'number': 7, 'name': u'07 Downstairs Motion', 'logChanges': False}
AD2USB Alarm Interface advancedBuildDevDict Called for devce:07 Downstairs Motion, Type:alarmZone, function:add
AD2USB Alarm Interface advancedBuildDevDict: Added record for Device:07 Downstairs Motion, Zone:07
AD2USB Alarm Interface advancedBuildDevDict: Wrote record:{'logSupervision': True, 'state': '', 'partition': u'1', 'board': u'13', 'name': u'07 Downstairs Motion', 'device': u'03', 'devId': 33894021, 'type': u'REL', 'number': u'07', 'logChanges': False}
AD2USB Alarm Interface deviceStartComm: devName:08 Phone Tamper, devId:1511284117, devTypeId:alarmZone, clearAllOnRestart:True
AD2USB Alarm Interface basicBuildDevDict: Added record for Device:08 Phone Tamper, Zone:8
AD2USB Alarm Interface basicBuildDevDict: Wrote record:{'state': '', 'devId': 1511284117, 'number': 8, 'name': u'08 Phone Tamper', 'logChanges': False}
AD2USB Alarm Interface advancedBuildDevDict Called for devce:08 Phone Tamper, Type:alarmZone, function:add
AD2USB Alarm Interface advancedBuildDevDict: Added record for Device:08 Phone Tamper, Zone:08
AD2USB Alarm Interface advancedBuildDevDict: Wrote record:{'logSupervision': True, 'state': '', 'partition': u'1', 'board': u'13', 'name': u'08 Phone Tamper', 'device': u'04', 'devId': 1511284117, 'type': u'REL', 'number': u'08', 'logChanges': False}
AD2USB Alarm Interface deviceStartComm: devName:09 Porch Sliding Door, devId:24090632, devTypeId:alarmZone, clearAllOnRestart:True
AD2USB Alarm Interface basicBuildDevDict: Added record for Device:09 Porch Sliding Door, Zone:9
AD2USB Alarm Interface basicBuildDevDict: Wrote record:{'state': '', 'devId': 24090632, 'number': 9, 'name': u'09 Porch Sliding Door', 'logChanges': True}
AD2USB Alarm Interface advancedBuildDevDict Called for devce:09 Porch Sliding Door, Type:alarmZone, function:add
AD2USB Alarm Interface advancedBuildDevDict: Added record for Device:09 Porch Sliding Door, Zone:09
AD2USB Alarm Interface advancedBuildDevDict: Wrote record:{'logSupervision': True, 'state': '', 'partition': u'1', 'board': u'', 'name': u'09 Porch Sliding Door', 'device': u'01', 'devId': 24090632, 'type': u'RFX', 'number': u'09', 'logChanges': True}
AD2USB Alarm Interface deviceStartComm: devName:11 PIR 45, devId:601314109, devTypeId:alarmZone, clearAllOnRestart:True
AD2USB Alarm Interface basicBuildDevDict: Added record for Device:11 PIR 45, Zone:11
AD2USB Alarm Interface basicBuildDevDict: Wrote record:{'state': '', 'devId': 601314109, 'number': 11, 'name': u'11 PIR 45', 'logChanges': True}
AD2USB Alarm Interface advancedBuildDevDict Called for devce:11 PIR 45, Type:alarmZone, function:add
AD2USB Alarm Interface advancedBuildDevDict: Added record for Device:11 PIR 45, Zone:11
AD2USB Alarm Interface advancedBuildDevDict: Wrote record:{'logSupervision': True, 'state': '', 'partition': u'1', 'board': u'0384004', 'name': u'11 PIR 45', 'device': u'01', 'devId': 601314109, 'type': u'RFX', 'number': u'11', 'logChanges': True}
AD2USB Alarm Interface deviceStartComm: devName:Alarm AD2USB Keypad, devId:880348765, devTypeId:ad2usbInterface, clearAllOnRestart:True
AD2USB Alarm Interface addPanelDev Called
AD2USB Alarm Interface addPanelDev: Added address to partition record:{'devId': 880348765, 'name': u'Alarm AD2USB Keypad', 'partition': u'1'}
AD2USB Alarm Interface addPanelDev completed
AD2USB Alarm Interface advancedBuildDevDict Called for devce:Alarm AD2USB Keypad, Type:ad2usbInterface, function:add
AD2USB Alarm Interface addPanelDev: Added partition to address record:{'devId': 880348765, 'name': u'Alarm AD2USB Keypad', 'address': u'31'}
AD2USB Alarm Interface runConcurrentThread Called
AD2USB Alarm Interface startComm Called
AD2USB Alarm Interface startComm: isAdvanced:True, commType:IP, address:127.0.0.1, port:15005, serialPort:/dev/cu.usbserial-A1018WW3
AD2USB Alarm Interface startComm: Read alarm status dict:{'010': 'armedAway', '001': 'armedStay', '000': 'Fault', '100': 'ready'}
AD2USB Alarm Interface startComm: Loading zonesDict
AD2USB Alarm Interface ad2usb opened for communication at socket://127.0.0.1:15005
AD2USB Alarm Interface panelMsgRead Called
AD2USB Alarm Interface panelMsgRead: isAdvanced:True
AD2USB Alarm Interface panelMsgRead: SER2SOCK connection or null Message: we passed on this one
AD2USB Alarm Interface panelMsgRead: panelMsgRead End
SENDING PANEL QUICK WRITE
AD2USB Alarm Interface panelQuckArmWrite Called
AD2USB Alarm Interface panelQuckArmWrite: Received:configured : True
delayAmount : 900
description : arm-stay
deviceId : 0
pluginId : com.berkinet.ad2usb
pluginTypeId : writeArmStayPanel
props : com.berkinet.ad2usb : (dict)
armingCode : #3 (string)
keypadAddress : 31 (string)
replaceExisting : True
textToSpeak :
AD2USB Alarm Interface panelQuckArmWrite: Created message:#3
AD2USB Alarm Interface panelMsgWrite Called
AD2USB Alarm Interface panelMsgWrite: Received msg:#3 for address:31
AD2USB Alarm Interface panelMsgWrite Completed
AD2USB Alarm Interface panelQuckArmWrite completed
AD2USB Alarm Interface panelMsgWrite: Received:configured : True
delayAmount : 900
description : write to panel
deviceId : 0
pluginTypeId : writeToPanel
****SENDING INDIVIDUAL CODE NUMBERS AS STRING TO THE PANEL TO SE T THE ALARM *****
panelMessage : (string)
textToSpeak :
AD2USB Alarm Interface panelMsgWrite: Created message:XXXXX <<<<<<<< THE CODE
AD2USB Alarm Interface panelMsgWrite: Received msg:XXXXX for address:31
AD2USB Alarm Interface panelMsgWrite completed
AD2USB Alarm Interface panelMsgRead: Calling advanced for:Sen
AD2USB Alarm Interface advancedReadZoneMessage Called
AD2USB Alarm Interface advancedReadZoneMessage: Received:!Sending......done
AD2USB Alarm Interface advancedReadZoneMessage Completed
AD2USB Alarm Interface panelMsgRead: raw zone type is:[100
AD2USB Alarm Interface panelMsgRead: Panel Message: Before:=[1000000100000000----],008,[f70000ff1008001c08020000000000],"****DISARMED**** Ready to Arm "
, Current=
AD2USB Alarm Interface panelMsgRead: Panel message:[1000000100000000----],
AD2USB Alarm Interface panelMsgRead: Found dev: Alarm AD2USB Keypad, id:880348765
AD2USB Alarm Interface panelMsgRead: current:0, last 0
hamw wrote:I have looked at your post and can see nothing that would cause the problem you are experiencing. All I can think is that you are possibly running a new firmware on the ad2*.Bump. Hoping to get this to work. I was running it on Indigo 7.1 and updated to 7.4.1 with no luck.
FWIW it is a new 20p panel, "WA20P" Rev 10.23
hamw wrote:That’s a good suggestion. Do you know the last compatible firmware version?
