Proliphix update thermostat status
Thu Oct 24, 2019 8:35 pm
SMUSEBY offline
I believe the Proliphix status update command is responsible for the following error message in the event log:
device "Thermostat" state key hvacHeaterIsOn not defined (ignoring update request)
Everything seems to be working, but the error code appears as four lines, every 5 minutes. I'm using v1.11.1 of the plug-in. The onset of the error MAY have coincided with the installation of Indigo v7.4.
Suggestions?
Fri Oct 25, 2019 6:34 am
berkinet offline
Re: Proliphix update thermostat status
Suggestions?
This plugin has not been updated in several years. So, if this problem is just now occurring, I doubt it is an issue in the plugin. Perhaps the Indigo device has become corrupted. You can try creating a new Indigo device to see if that clears the problem.
