Version 0.5.0 of the Indigo Netatmo plugin is now available from
dropbox.
NOTE WELL: This is very beta, maybe alpha. Also known as IWHFM* ware
What does work:
• Station device measurements are, once again, loaded into Indigo.
• The Rain Guage is supported
• Multiple Stations
should work. But, it has not been tested (If you have more than one station, please test and let me know)
What does not seem to work:
• Wi-Fi status on the base station is not being updated
What you need to do to get this working, and use it in Indigo:
• Install and start the plugin
• Re-define all of your Indigo Netatmo devices (open, Edit, save and close)
• Restart the plugin
• If you use any of the states in Indigo triggers, scripts, actions or Control Pages you may need to make a few changes.
- Co2 is now CO2
- Last_Observation is now When (this will probably change back at some point)
- RF_Signal is now rf_status
- Battery_Level is now battery_vp
-- In other words, all states now match the Netatmo API terminology
New states have been added , as appropriate, to conform with the data available from Netatmo:
• max_temp
• date_max_temp
• min_temp
• date_min_temp
• AbsolutePressure
• sum_rain_1
• sum_rain_24
• Rain
It
Works
Here
For
Me
