Netatmo plugin discussion
Mon Aug 26, 2013 2:02 pm
otto-mate offline
Re: Netatmo plugin discussion
berkinet wrote:
Click Edit Action Settings... For Insert State: Select Temperature and for Into Variable: select the variable (it must already exist) you wish to save the temperature into.
Thanks berkinet, that's perfect.
M.
Tue Aug 27, 2013 5:54 am
berkinet offline
v0.4.0 available
Version 0.4.0 of the Netatmo plugin is now available. Please see the Netatmo Announcement topic for more information.
Sat Aug 31, 2013 11:36 am
nicb offline
Hi, I just got my NetAtmo and dove straight in to the 0.4.0 plugin, but it is erroring for me:
31 Aug 2013 18:31:15
  SQL Logger Error                exception trying to insert row into table device_history_1965852535 ("NA Outdoor") -- unable to modify table
  SQL Logger Error                near "when": syntax error
  SQL Logger Error                INSERT INTO device_history_1965852535 (battery_level, humidity, rf_signal, temperature, when) VALUES (%s, %s, %s, %s, %s);
I have deleted the devices and tried a couple of times, but am consisternly getting these table creation errors. Any ideas? Thanks.
-Nic
Sat Aug 31, 2013 12:41 pm
AndrewGWalsh offline
Isn't this a problem with the SQL Logger plugin? It tries to create field names to match those on the devices even if the field names are reserved words ('when') in SQL.
I suspect your NetAtmo plugin is functioning fine.
The SQL Logger plugin could perhaps map reserved words to something slightly different or the NetAtmo device names could be changed - it would be more robust IMO to change the SQL Logger plugin.
Andrew
Sat Aug 31, 2013 1:07 pm
berkinet offline
AndrewGWalsh nailed it. I just used the names Netatmo gave the fields in their API. I have revised the plugin to use Observation_Time as the state name in place of When.
Version 0.4.1 is available on dropbox. You do not need to delete the existing Netatmo devices. Just open them, click Edit Device Settings... and then save and close.
Sat Aug 31, 2013 1:10 pm
Now _that_ is software turnaround....
Sat Aug 31, 2013 1:16 pm
nicb offline
Yeah! Fast work, I was just testing...
I was still getting an error
  Netatmo Plugin Error            Error: -'NoneType' object is unsubscriptable- reading data for Indigo device 'NAOutdoor'
so I deleted the devices and recreated. All seems to be working now.
Thanks very much!
Sat Aug 31, 2013 1:33 pm
berkinet: Thanks for working around the problem (in the SQL plugin) in your plugin. We need to modify the SQL plugin as well to handle the use of reserved words.
Tue Sep 03, 2013 12:30 am
col offline
Is the download link broken? getting a 404 error
Ignore, just found it
Tue Sep 03, 2013 12:42 am
berkinet offline
Glad you found it. I also just updated the link to v0.4.1. Minor change to support users of the SQL Logger plugin.
Thu Jan 30, 2014 6:56 pm
Seeker offline
i noticed IFTTT just added netatmo recipes. not sure what good it does with indigo, but interesting.
http://blog.ifttt.com/post/74288176359/ ... nel-plus-a
Mon Feb 03, 2014 12:14 pm
oliverjhudson offline
Will this plugin work with the standalone thermostat as well, or does it only handle the weather station?
Mon Feb 03, 2014 4:09 pm
berkinet offline
It will definitely not control the thermostat. It may report the thermostat's readings.
Sun Feb 23, 2014 5:09 pm
orangy offline
Works perfect, thanks! I'd like to may be help improve it, do you have github repository with sources or something?
Tue Mar 11, 2014 3:31 pm
zeigh offline
Re: Netatmo plugin
Has anyone had issues with this Netatmo plugin (0.4.1) in the last few days? It is suddenly unable to connect online for data when all other plugins are working fine, as well as my Netatmo user name/password connecting on their web portal. Here is a sample of the repeated Indigo log text:
Netatmo Plugin Error plugin runConcurrentThread function returned or failed (will attempt again in 10 seconds)
Netatmo Plugin Debug Entered: Funct runConcurrantThread
Netatmo Plugin Debug Entered: Funct readNetatmo
Netatmo Plugin Debug Entered: ClientAuth init
Netatmo Plugin Debug Entered: Funct postRequest
Netatmo Plugin Error Plugin stopping. Reason = 'scope'
Netatmo Plugin Stopping Netatmo device read loop
“Technological change is like an axe in the hands of a pathological criminal.” (Albert Einstein, 1941),
Dr. Z.
