terrydew wrote:Any plans to add non true/false states for variables?
terrydew wrote:Actually I was thinking of a user defined number or text for the on and off values... ...For example the user could define "closed" to be "true" and "open" to be false.
bbruck wrote:...First, I have areas of my house where there are multiple motion detectors, and this seems like a perfect situation. So if ANY of my basement motion detectors is activated and it's night time, then a light might come on. Is this the sort of situation you envisioned?
bbruck also wrote:...Second, I'm thinking of a simple "presence awareness" use... ...I'm having a little trouble with the "off after 5 minutes" logic however. What I want is this:
If none of the three motion detectors have detected motion in the last five minutes, set the variable BasementOccupied to False.
and bbruck also wrote:Documentation error. I'll get that fixed. The option still applies even if the Action is contained in the Trigger.BTW - buglet? When choosing Use Action in this Trigger, I still see Process Trigger Conditions? - shouldn't this latter be suppressed in this case as per the documentation or did I read it wrong?
