strudel wrote:Just purchased a Netatmo Base Station, 2 x Indoor modules, outdoor module and a rain sensor. I run Indigo 6. I have tried installing 0.5.4 and 0.5.5 and get the same problems with both when trying to run the plugin. Any help would be appreciated.
The main error I get is " Netatmo Plugin Error Plugin stopping. Reason = 'NoneType' object has no attribute 'items'"...
strudel wrote:Originally, I added the base station first and I got the error. ...
Netatmo Plugin Error Plugin config is missing user credentials
strudel wrote:Yes, I set the user name and password to the same that I am using for the iOS client and their website. My email address (user name) is very short (7 characters including @ & .).
strudel wrote:I copied it and PMed it. I changed my password on my account and the new password is reflected in the config I sent you. Feel free to test on your end to see if this is specific to my account or my Indigo instance... Thanks for your speeds response on all of this.
strudel wrote:I used the exact same name (case sensitive) in each possible location. The Netatmo website, the station name, device name and module name are all the same. I have tried it just for the base and have tried it with all the devices. I don't get any errors until I actually add a device. Feel free to use my account.
AndrewGWalsh wrote:Hello all, I am experiencing a problem with my Netatmo setup on Indigo and am guessing it is configuration because no one else is reporting difficulties.
I am getting:
Netatmo Plugin Debug Entered: Funct runConcurrantThread
Netatmo Plugin Debug Entered: Funct readNetatmo
Netatmo Plugin Error Plugin stopping. Reason = HTTP Error 400: Bad Request
Netatmo Plugin Stopping Netatmo device read loop
Netatmo Plugin Error plugin runConcurrentThread function returned or failed (will attempt again in 10 seconds)
in the log file every few seconds - does anyone know what this might relate to. I've tried re-installing and my web based Netamo login seems ok; ...
