Group Trigger Plugin
Mon Jul 31, 2017 9:16 am
JohnS offline
Re: Group Trigger Plugin
Berkinet,
You were right on. Somehow I had a leak detector that was 36.D0.73 but had a different address in the indigo database. Redefining and syncing the leak detector cleared everything up.
Thanks again, John
Sun Aug 26, 2018 4:09 am
Dewster35 offline
Any plans for this being enhanced to support devices that are from the fingscan plugin?
Sun Aug 26, 2018 4:41 am
berkinet offline
Sorry, no.
Sun Oct 08, 2023 11:07 am
siclark offline
Hi.. are there any plans to upgrade this to python 3? I still use this for some of my motion triggers where the action is triggered from any one of several motion sensors.
Would be great to not have to duplicate all my triggers, one per sensor.
Simon
Sun Oct 08, 2023 11:26 am
Simon
Check out the Occupatum plugin.
Sun Oct 08, 2023 1:11 pm
berkinet offline
Simon
I can probably do a conversion on the group trigger plug-in. However, before I start the work, I would suggest you take a good look at the plug-in, flying diver has suggested. If that can meet your needs, then I would be quite happy to let the group trigger plug-in simply expire .
Sun Oct 08, 2023 1:15 pm
If all the other plugins did was "group" multiple sensors, then Occupatum will definitely do the job. Plus a lot more, if you need it.
Sun Oct 08, 2023 2:04 pm
siclark offline
Thanks. I got confused when I looked at it after it was first released but sounds like I need another look.
Sure it will suffice
Tue Oct 10, 2023 4:52 am
siclark offline
Thanks both. Yes that plug-in is perfect and simplifies my use of group triggers and timers massively.
I am now upgraded and only python 3.
Tue Oct 10, 2023 6:18 am
berkinet offline
Good to hear!
